I am using ICEM 10 and trying to create a pure tet mesh. The model will mesh, but when it tries to smooth transition I get this error. I have a nice surface mesh, but my interior volume mesh gets really coarse near the middle since smooth transition fails. This is why I want smooth transition. I tried to find the below edge and face numbers, but to no avail. I have gone to repair geometry and checked all surfaces and curves and after I remesh I get the same message. Can anyone help me? Thank you.
ERR 3106 : SURFACE EDGE 151508 151509 INTERSECTS WITH FACE 52187 52721 54698 ERROR:3106 - A surface edge intersects a surface face status 1 Application did not finish correctly. Error: tri2tet exited with a non-zero status Warning: Smooth transition failed |
I normally just dick around with the mesh sizing to avoid this issue.
Over specification of volume mesh size constraints can also trigger this. |
maybe deleting the edges around the problem will help.
The edges help define where the mesh conforms. The problem is that I cannot find where this edge intersects this face. I have hundreds of edges, so it's not easy finding it especially if there isn't a way to find that edge and face number in ICEM. All my surfaces are named, but if I select a face it will say "face"/25, when the error shows a generic face number that is internal to ICEM.
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
