November 7, 2021, 15:58 |
The variational multiscale method
David
Rep Power: 12 |
Is there anyway to employ variational multiscale method [1] to solve the Navier-Stokes equations in ANSYS? Is it correct that this formulation can model the transition from the laminar to turbulent flow regimes in a problem? I am modeling the blood flow through heart valves. In this problem, we know that we have both laminar and turbulent flow regimes in a cardiac cycle. I tried to model the flow using a laminar model as an approximation of the accurate solution. Is this a valid approach? [1] https://en.wikipedia.org/wiki/Variat...tiscale_method |
November 7, 2021, 17:17 |
Rep Power: 143 |
That looks like a method still in the research stage to me. I suspect you will need to be an expert in numerical methods to implement that, and if you are an expert in numerical methods then you will have written your own CFD solver to make best use of the features of the approach rather than use a commercial code. And then taking an experimental numerical method and applying it to a heart: with moving walls, complex rheology, laminar/turbulent transition and complex geometry....... I think I can safely say this is not realistic.
Simply put, you can be sure all numerical methods which are validated to work on a wide range of flows and can be implemented in a Navier Stokes solver like CFX are already in it. So what is a realistic approach? If the Reynolds number is low then modelling the flow with a laminar is quite feasible. I used that exact model in my PhD thesis as a simple LES model. See my thesis, Chapter 6, for the justification of it and the results (it worked quite well): https://opus.lib.uts.edu.au/handle/10453/20133#
November 9, 2021, 14:42 |
David
Rep Power: 12 |
Dear Glenn,
Your help is much appreciated. Thank you for sharing your Ph.D. thesis with me. LES seems to be the solution. |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 14:32 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase() | maybee | OpenFOAM Programming & Development | 0 | December 21, 2013 10:13 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
About flowfield-dependent variation(FDV) method? | Jinwon | Main CFD Forum | 1 | December 4, 2007 21:13 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 02:34 |
