November 23, 2021, 00:14 |
CFX ERROR:Stopped in routine TRCPRT
WEI Liangchuan
Rep Power: 4 |
I'm using cfx to perform condensation flow calculations with a mixed mass (steam3l+steam3v+H2 Ideal gas), and I always get the following error when I reach the last step of the calculation. What is the problem and how can I change it?What does TRCPRT mean?
GETCORE stacktrace 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 2 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 3 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 4 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 5 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 6 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 7 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 8 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 9 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST Partition: 10 1 Post_Soln, ,CVVOL,ZN1/VERTICES,LATEST 2 Post_Soln, ,ORTHANGLE,ZN1/VERTICES,LATEST 3 Post_Soln, ,CVVOL,ZN2/VERTICES,LATEST 4 Post_Soln, ,ORTHANGLE,ZN2/VERTICES,LATEST 5 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 6 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST 7 SU_HYBARR, ,DGIBBS_FL3,VERTICES,LATEST 8 SU_HYBARR, ,TABS_FL3,VERTICES,LATEST +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine TRCPRT | | | | | | | | | | | +--------------------------------------------------------------------+ Last edited by Liangchuan; November 23, 2021 at 00:15. Reason: I lost my error message. |
November 23, 2021, 03:16 |
Rep Power: 143 |
The error messages in CFX are not very helpful sometimes.
All I can suggest is to simplify the model and add the complexity one step at a time. Does it run single phase? Then try with steam3l+steam3v only. If that works then add the H2. At least this will tell you which bit of the physics is causing the problem.
November 23, 2021, 03:53 |
#3 | |
WEI Liangchuan
Rep Power: 4 |
November 23, 2021, 04:04 |
Rep Power: 143 |
How are you modelling this? I presume steam3l+steam3v is a homogenous binary mixture, but how have you included H2? Or is it all a multicomponent mixture?
Please upload your CCL or output file.
November 23, 2021, 04:41 |
cfx-pre ccl
WEI Liangchuan
Rep Power: 4 |
This is the ccl file of my cfx-pre, I copied it to the txt file, please give it a look
November 23, 2021, 05:10 |
Rep Power: 143 |
You appear to have modelled a multiphase model with h2 as a dispersed fluid, s3l as droplets with phase change, s3v as a continuous fluid. Did you intend to model this as a homogenous binary mixture? The s3l and s3v materials appear to be intended to be used in a homogeneous binary mixture.
Are you sure you are using the correct multiphase model?
November 23, 2021, 05:26 |
#7 | |
WEI Liangchuan
Rep Power: 4 |
November 23, 2021, 16:58 |
Rep Power: 143 |
Please read the documentation about homogeneous binary mixtures. You cannot use them if you do not understand them.
A homogeneous binary mixture is two phases of the same material (eg water vapour and liquid water) which are linked together in CFX so the phase change between the two phases can be modelled. You cannot have 3 materials in a HBM, and you cannot have different materials in a HBM (eg water and H2). I suspect you want a HBM between water and its vapour, but you then want a multicomponent mixture between the HBM and H2. But you should understand these models so you are sure you select the correct one. There are other ways of mixing them together which might be appropriate depending on what you are doing.
cfx, error #001100279, trcprt |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 8, 2006 23:03 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
CFX 5.7 error by routine PEEKCS and MEMRR | H.L. | CFX | 3 | October 25, 2004 09:01 |
