November 25, 2021, 09:17 |
General momentum source velocity query
Stuart
Rep Power: 25 |
In CFX Modeling Guide section 1.3.2.2.2 it gives the equation: for a general momentum source. must be the velocity components at a location as calculated by the solver, but what exactly is ? This can be determined by Expressions, User Functions etc, but I don't think it can be consider as a 'specified' velocity. The Modeling Guide does not directly state this.
Thanks. |
November 25, 2021, 16:56 |
Rep Power: 143 |
The U(i,spec) is the velocity you want to have at that point. It can be a constant, a function or anything. As it is the velocity you want, they call it the specified velocity. Does that explain it?
November 26, 2021, 01:57 |
Stuart
Rep Power: 25 |
Thanks Glenn. I am writing a report and just wanted to state this parameter accurately and specified velocity will do nicely.
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
