May 19, 2007, 02:24 |
How to find hole in mesh
Dear friends When I mesh ICEM CFD It shows some hole How I can detect the holes in gometry. How I can repair hole in mesh also I tried hole repair but it not give what are the element in hole.
May 21, 2007, 00:32 |
Re: How to find hole in mesh
hai generally the hole repair is not a fair thing to do rather you can improve your mesh by changing the mesh parameters. anyway for locating the bad mesh elements what you can do is check for mesh quality the negative elements will be shown just click on the bar of negative elements it will show where are they located.
May 21, 2007, 23:49 |
Hi Abdul, Thanks for your suggestion,I am also try for that. Is this hole in geometry cause by hole tollerence or by the size of globale parameter mesh size.
May 22, 2007, 03:26 |
yes it could be caused b'coz of either global mesh size or surface mesh parameter. so you have check both.
May 24, 2007, 06:38 |
To remove this hole before meshing can I proceed with surface mesh then I go for volume mesh?How can I determine the element in which hole is occours?
May 24, 2007, 07:06 |
After defining your parts for the mesh,keep global size 1, and give mesh sizes in your part mesh set up.Then right click on your geometry>surfaces>show tetra sizes or say hexa sizes which will give u an idea about your mesh size. To see the holes in your geometry say show full and soli&wire from the same menu.And if your geom does not have any holes,then your mesh sizes may be greater so that it will not capture your geometry and will create holes. So just practice.
[Commercial meshers] FluentMeshToFoam Cannot find a single face in the mesh which uses vertices | francesco_b | OpenFOAM Meshing & Mesh Conversion | 8 | December 2, 2020 02:57 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
mesh around suction hole | morteza08 | ANSYS Meshing & Geometry | 0 | August 18, 2010 07:48 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
