Additional variable - wall boundary condition
Old   May 29, 2007, 12:19
Default Additional variable - wall boundary condition
flga
I have defined a additional variable, and I have defined fixed values for it in the inlets and outlets (in case of recirculation occurs).
What I couldn't do is to define a fixed value for my additional variable at the wall boundary conditions. In the CFX manual is written that it is possible, and that it works in the same way as the heat transfer boundary conditions, but I haven't found a way to set it up in CFX.
Any help will be appreciated.
flga
Old   May 29, 2007, 14:13
Default Re: Additional variable - wall boundary condition
opaque
Dear flga,
If you set the Kinematic Diffusivity for your Additional Variable, then you can specify the wall value. Otherwise, the value at the wall is irrelevant since it cannot diffuse.
Hope it helps,
Opaque
Old   May 30, 2007, 03:14
flga
Thanks, Opaque! It is working now.
UDF setting wall boundary condition with a DEFINE_PROFILE NLao FLUENT 3 September 2, 2019 00:33
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 09:28
wall boundary condition safa_c Main CFD Forum 1 August 9, 2010 12:55
Wall boundary condition in cylindrical co-ordinate shekharc Main CFD Forum 3 December 2, 2009 08:20
Wall thickness boundary condition mskim FLUENT 0 February 14, 2009 16:37
