June 14, 2007, 04:52 |
Vorticity
Hallo Is there an option in CFX 11 post to visualize and extract vorticity in the flow field?
Rgrds, Selim |
June 14, 2007, 05:42 |
Re: Vorticity
Turn in on under Trasient Results
June 14, 2007, 07:18 |
Re: Vorticity
Thks,I have seen it.
But is it not possible from CFX-post? I define the vorticity(only 1 component for 2d flow) For the transient simulation ,at all time steps this value is the same.Is this possible,or simply I cannot create such expressions in CFX post for transient case? Rgrds, Selim |
June 14, 2007, 22:42 |
Re: Vorticity
Vorticity is not written to the .res file by default. You need to enable it, you need to include the following CCL:
LIBRARY: VARIABLE: vorticity Output to Postprocessor = Yes END END You could run your current .res file for one iteration with this CCL to generate the vorticiy. |
June 15, 2007, 03:55 |
Re: Vorticity
Thks for the replies
I have a transient simulation of 2000 time steps. Rgrds, Selim |
Calculation of Vorticity | mortain | Main CFD Forum | 1 | July 12, 2010 04:10 |
How to implement vorticity calculations | mortain | Main CFD Forum | 0 | July 1, 2010 13:26 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
vorticity calculation at symmetryplane | benconnell | OpenFOAM | 0 | April 14, 2009 18:45 |
Vorticity Iso-Surface | John | Main CFD Forum | 0 | April 4, 2009 23:10 |
