Hello. Im meshing a spiral duct. The duct is composed by 13 sections of different sizes, going from a big section to a small section. Im meshing the duct by creating the blocks of 1 section (the big one), and then extruding the faces and doing the correct association for each section.
The problem is that when I extrude the smallest section, each edge conserve the params of each section. I mean, the params of the edge (any edge) in the big section, conserve the same params in the small section (the same edge of the big section). Does any body knows how to unlink that association? I tried setting the params without putting the option COPY SAME TO PARALLEL, but doesnt work. Thanks Santiago. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[Gmsh] Cannot get the right mesh from gmsh | JinBiao | OpenFOAM Meshing & Mesh Conversion | 2 | August 31, 2010 04:51 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
