ICEM Extrude faces - Edge params.
Old   June 19, 2007, 12:08
Default ICEM Extrude faces - Edge params.
Santiago Orrego.
Hello. Im meshing a spiral duct. The duct is composed by 13 sections of different sizes, going from a big section to a small section. Im meshing the duct by creating the blocks of 1 section (the big one), and then extruding the faces and doing the correct association for each section.
The problem is that when I extrude the smallest section, each edge conserve the params of each section. I mean, the params of the edge (any edge) in the big section, conserve the same params in the small section (the same edge of the big section).
Does any body knows how to unlink that association? I tried setting the params without putting the option COPY SAME TO PARALLEL, but doesnt work.
Thanks Santiago.
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 04:51
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
