April 1, 2022, 06:09 |
Pressure change interface
Jin Seok Lee
Rep Power: 4 |
I used pressure change interface to consider pressure difference about thin filter instead of using porous model.
First, I made 1D function by using userfucntion (reference image1) and I made Interface between 2 domain. Finally I applied 1d function's about pressure drop in surface of interface between 2 domains and I simulated. When I reviewed, I knew that the result is wrong! Inlet velocity is 3m/s(reference image3) and It means that interface pressure of difference should be about 70 ~ 80Pa. (Inlet velocity 2.8m/s > -57[Pa], Inlet velocity 3.5m/s > -81[Pa]) But interface pressure of difference was very small (Pressure is about 3Pa.. reference image3) I reviewed why the result is wrong for days. But I couldn't find pressure change interface information in google, customer portal, ansys cfx example, you-tube, CFD online and so on. So, I really need to help. Please give me advice Thank you 1. image1 > cfx pre image & userfunction image image1.jpg 2. image2 > interface pressure change image2.jpg 3. image3 > Velocity & Pressure result image image3.jpg 4. output file CFX_001.txt Last edited by jins9158; April 3, 2022 at 20:57. |
April 1, 2022, 17:56 |
Rep Power: 143 |
Your links do not work. But please do not post images on third party sites, post them directly on the forum: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
To answer your question: Please post your output file.
April 3, 2022, 19:44 |
#3 | |
Jin Seok Lee
Rep Power: 4 |
I am sorry to bother you |
April 3, 2022, 20:05 |
Rep Power: 143 |
April 3, 2022, 20:42 |
Jin Seok Lee
Rep Power: 4 |
April 3, 2022, 21:16 |
Rep Power: 143 |
You have defined a positive pressure change across the filter. The pressure is higher on the downstream side of the filter than the upstream side. If this is what you intend then you might have invented a perpetual motion machine.
But I suspect you did not want to do this. The pressure drop across the interface is defined as a positive number to give you a pressure drop in the direction of flow.
April 3, 2022, 21:57 |
#7 | |
Jin Seok Lee
Rep Power: 4 |
I have some questions. Is the local coordinate also applyed in this matter? When I tested, I realized that local coordinate was not applyed. I need to simulate about ventilation system that have several filters So I need to use local coordinate to apply difference of pressure. |
April 3, 2022, 23:41 |
Rep Power: 143 |
I have never used the local coordinate option with that. You will have to test it and work it out, or read the documentation.
April 4, 2022, 01:06 |
Jin Seok Lee
Rep Power: 4 |
April 4, 2022, 07:02 |
Gert-Jan
Rep Power: 27 |
If I'm correct you can use this interface with pressure specification only in a translational periodic setup. Imagine you have pipe with 100 obstacles in line with fixed distance, then you model a section with 1 obstacle. Then add a periodic interface, allowing you to couple the outlet with the inlet.
Then you can choose a pressure drop over the 1/100-th pipe section, which results in a massflow. Or you specifcy a massflow and you get a pressure drop. Last edited by Gert-Jan; April 4, 2022 at 08:32. |
April 5, 2022, 02:55 |
#11 | |
Jin Seok Lee
Rep Power: 4 |
could I give some question? you said that the pressure is higher on the downstream side of the filter than the upstream side. This answer made me to confuse becasue the porous domain's result about tutorial is different. When I used porous domain to appy pressure's drop, the pressure is higher on the upstream side of the porous domain than the downstream side. Aren't they option about pressure loss in both? why are they different? Please give me advice |
April 5, 2022, 03:05 |
#12 |
Rep Power: 143 |
I think the pressure is higher downstream of the interface in this case because you defined a negative pressure jump over the interface. If you made it a positive number you would get lower pressure downstream which I suspect is what you want to do.
April 5, 2022, 11:06 |
#13 |
Erik
Rep Power: 23 |
I'm confused, you only use "filter" but do not define the independent variable "velocity".
shouldn't you have to put in filter(Velocity) or filter(Velocity w) or whatever the correct variable is? Or does it just assume velocity is the independent variable? |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
