How to monitor mass flow conservation and point velocity in .out files |
April 5, 2022, 07:23 |
hang yang
Rep Power: 4 |
I would like to monitor the difference in inlet and outlet mass flow, as well as the velocity values at some points, to judge convergence. I know it can be done using the Monitor function, but I am using a supercomputing platform and cannot view the Monitor curve. Someone knows how to write this data in .out file or output it to some file so that I can Monitor convergence.
April 5, 2022, 08:24 |
Rep Power: 32 |
I think you mean to monitor mass conservation, not convergence.
Nothing gets written to the output file unless is explicitly coded, so you must rely on the existing features. Have you checked the "expert parameters" panel in CFX-Pre. There is a section for monitoring ranges, scales, etc. If I recall correctly there used to be a "monitor totals" that will output the same "end of simulation" report with all the equation flows and imbalances (it will make your output file a lot larger though)
April 5, 2022, 19:18 |
Rep Power: 143 |
You can monitor the imbalances/mass conservation in Solver Manager by adding a new monitor and selecting the imbalances you wish to monitor. You can also monitor velocities at points by defining a monitor point at that location in CFX-Pre and then you can monitor it in Solver Manager as the solution progresses.
April 5, 2022, 22:06 |
#4 | |
hang yang
Rep Power: 4 |
April 5, 2022, 22:56 |
Rep Power: 143 |
Solver Manager works fine on remote systems. As long as you can see the working directory Solver Manager will work.
An alternative method is to use the command line tools to extract the plots. I think the command is cfx5mon - but check the documentation for the syntax.
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
buoyantBoussinesqPimpleFoam: conservation of mass violated | piu58 | OpenFOAM Running, Solving & CFD | 2 | April 12, 2018 02:02 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Velocity profile disturbance due to loss coefficient | rks171 | Main CFD Forum | 3 | May 25, 2012 17:30 |
