how to repair geometry by another way
Old   July 16, 2007, 09:58
Default how to repair geometry by another way
Priscila
Friends
I've built a geometry, and when I try to make a mesh, it's appearing a notice I can't continue because my geometry has a hole and ask me if I want to fix it. If I say yes, it goes to Repair Mesh and it appears a red line in my geometry. I don't know what to do after... Someone can help me to repair the geometry (close the hole) by another way? Thanks
Old   July 16, 2007, 10:12
Default Re: how to repair geometry by another way
myron
If you are talking about ICEM CFD - the red line is giving you the 'leakage' path of the mesh. First you need to determine what in the geometry is causing the 'leakage' - then you can figure out how to correct the geometry.
Old   July 16, 2007, 12:16
Gert-Jan
It appears that you need an additional surface there to close the hole. You can create the surface by selecting the edges and select submit.
I recommend to do this in the "geometry menu" before you go to the "meshing menu". Just make all surfaces "solid" to see if someting is missing, close all gaps and off you go.
Good luck, Gert-Jan
Old   July 17, 2007, 11:42
Ressel
Check if you have defined all surfaces/families and don't forget to verfiy the tolerance if you are working with little geometries.
Ressel
Old   August 2, 2007, 11:43
Priscila
Thank you guys for your help!!
" your geometry has a hole. Do you want to repair it?" moca ANSYS Meshing & Geometry 2 February 14, 2018 00:15
[GAMBIT] Geometry repair doodek ANSYS Meshing & Geometry 5 February 10, 2011 14:42
ICEM --- question about repair geometry zhaohui ANSYS Meshing & Geometry 1 April 21, 2010 18:54
repair the geometry in the ANSYS-ICEM feixiangniao ANSYS Meshing & Geometry 3 March 31, 2010 05:53
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
