About CFX11 low temperature for heat transfer
Old   July 24, 2007, 21:58
Default About CFX11 low temperature for heat transfer
karke
Now i have found a question in CFX11.0 for all type of heat transfer problem. It will occur the very low temperature in some area(below the enviroment). Anybody have some solution about this?
Old   July 26, 2007, 18:57
Default Re: About CFX11 low temperature for heat transfer
Is your solution properly converged? Probably not I guess.
Glenn
Old   July 26, 2007, 22:16
karke
You can test this in the CFX tutorial 18. But it is not only this case, there are a lot of this type of CHT questions occure in the Version10.0 and 11.0. I also test this in Version 5.7.1,it is okey, So i think it is caused by the numeric scheme change from Version5.7 to 10.0 or 11.0.
Old   July 29, 2007, 18:26
Yes, there have been changes to the numerics over the years. The default differencing scheme in CFX is High Resolution which has some second order in it so it will potentially lead to undershoots/overshoots. The high res scheme tries to minimise these under/over shoots - have a look at the documentation.
For further reading on the effects of differencing scheme have a look at the book "Computational Fluid Dynamics" by Roache. This book explores accuracy and errors in CFD in detail.
Regards, Glenn Horrocks
Old   July 29, 2007, 21:58
karke
Thanks,Glenn Horrocks
Now in my practicle CHT question,I will change the energy sheme to up wind,thus it will some time avoid the low temperature. But it will not always useful.
Old   July 30, 2007, 19:34
Yes upwind will also eliminate the problem but will reduce the accuracy of your simulation. You will need a very fine mesh to get accurate results with first order differencing. Do a mesh refinement study to check your accuracy.
Old   July 30, 2007, 21:10
karke
Hi, The following is the explain from the headquater:
1) The "Freestream Damping Option" for the High Resolution advection scheme was changed from 1st order (5.7.1) to 2nd order (10.0 and 11.0). To see the difference, look at the "Energy and Mass Fractions.Beta" variable in Post 2) By default energy is excluded from calculation of the common Beta for energy and mass fractions.
Because of 2) the HR Beta for energy is determined from the component mass fractions alone, and because of 1) in 10.0/11.0 the advection scheme will be second order in regions of constant composition (in 5.7.1 it used to be blended to 1st order). However, if temperature gradients are present in such a region, then the second order scheme may cause oscillations/over-/under-shots as observed in the current case. In 5.7.1 such regions were blended to 1st order, which did avoid the oscillations, but at the cost of reduced accuracy in regions where we could afford the higher order.
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Shell Model for Low Temperature Combustion Phil Main CFD Forum 0 March 17, 2006 00:34
heat transfer coefficient Peter Main CFD Forum 7 August 26, 2001 18:44
Low Re k-e model and heat transfer Abhijit Tilak Main CFD Forum 1 July 5, 2000 05:32
