golf bal simulation
Old   August 5, 2007, 12:56
Default golf bal simulation
jan
i have problems to simulate a turning golfball , altough i can simulate one in fixed position i want to simulate that it in 3 directions and find out what the best is in certain direction and speed so left turning or the other way right turning
i only can find to simulate moption of a whole domain with a inlet , so guess this is not right for this kind of simulation or is it?
Old   August 6, 2007, 15:47
Default Re: golf bal simulation
jan
any one??????
Old   August 6, 2007, 18:32
I am assuming you are modelling the golf ball dimples spinning. I would use a rotating frame of reference to do this. You can change the rotation axis and direction to generate different ball spins.
Correctly modelling the effect of the dimples on the boundary layer would be difficult and will require careful validation. Good luck.
Old   August 6, 2007, 18:54
jan
hi glenn thanks i have used rotating frame,but how do i see in simulation how the ball is spinning altough the boundery layers is second order first i want to see the ball spinning and its effect then the change in mesh but now i just cannot see any movement is it me or...........
Old   August 8, 2007, 07:03
To see the spin fire up CFX-Post and look at the mesh. You will see it spin (If you have set it up right!). You should also see the effect of the spin in variables such as "Velocity" (measured relative to the local frame of reference, in this case rotating) and "Velocity in Stn Frame" (measured relative to a stationary or absolute frame of reference).
Old   August 8, 2007, 07:46
jan
well thats the problem i see the velocity in stn frame but not any movement of mesh so i do something wrong but what?
Old   August 8, 2007, 11:38
brunoc
Hi there,
If your simulation is steady state then your final solution won't have "mesh motion". To see it "moving" you will have to set it manually, I guess by using keyframes on CFX-Post.
If, on the other hand, your did a transient simulation (and thus used Transient Rotor-Stator interface) all your transient results will already have "mesh motion" embedded.
Old   August 8, 2007, 12:22
jan
you say ." to see it moving you have to set it manually "
but what do i set manuallt then
key frame in animation does not show me moving mesh
i am really stuck with this one
Old   August 8, 2007, 13:52
brunoc
If you did a steady state simulation your results file holds only the variable values of an average in time. Your mesh is actually still. You motion would just be post-processing.
Keyframe won't show you the mesh moving unless you tell it to do so. I've never done this, but my guess is that you'd have to manually rotate your the golf ball by small angles and create keyframes according to these changes.
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
