September 23, 2022, 13:50 |
Set properties of cells inside domain
Rodrigo Villarreal
Rep Power: 9 |
I need to assign the thermal conductivity of the "layer" of cells next to the boundary to the adjacent "layer" of cells inside the domain.
In the attached image, it will be something like assign the thermal conductivity of the orange line to the green line. Does anyone know how to do it or if is it possible? Thanks for your response. |
September 25, 2022, 16:06 |
Gert-Jan
Rep Power: 27 |
If it are different solids, then you should create a volume with only the orange elements, assign it to a new material with a different conductivity.....If you have a liquid and are trying to modify the conductivity close to the wall, then there must be a specific reason. If so, then what are you trying to do exactly?
September 25, 2022, 18:30 |
Rodrigo Villarreal
Rep Power: 9 |
I'm trying to decrease an enormous gradient near the wall by making thermal conductivity artificially high. The huge gradient of temperature is created by resistive heating due to an electrical current that passes through the fluid. I've tried a constant value, but it doesn't work properly.
September 28, 2022, 15:19 |
Erik
Rep Power: 23 |
It does not sound like what you are trying to do is realistic. The artificially high conductivity of the fluid is not realistic, and it any results obtained using it would be meaningless, so i don't understand the reasoning for trying to do this.
But If you really wanted to, you could probably make the conductivity a function of y (or another location based definition) |
September 28, 2022, 16:27 |
Rodrigo Villarreal
Rep Power: 9 |
Thanks for your reply.
Yes, it's not realistic, but I'm trying to see if it works. I'll try the location based approach. |
October 8, 2022, 04:32 |
Rep Power: 143 |
This sounds like a classic XY problem to me (https://en.wikipedia.org/wiki/XY_problem)
Why do you think this gradient is unrealistically high? Is it is problem anyway? If you are just adding heat to a liquid it might not matter if the gradients are huge. Should there be other physics at play (eg boiling?). Do you need a finer mesh to resolve it properly? Or maybe a turbulence model?
cel fortran cfx, cfx, cfx + fortran |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] snappyHexMesh not deleting the inside cells | Bdew8556 | OpenFOAM Meshing & Mesh Conversion | 9 | May 14, 2019 10:53 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
