November 16, 2022, 18:03 |
Could not invert control surface Ap
QC
Rep Power: 7 |
Dear All,
I am working with Ansys CFX for more than 10 years. During this period, I had no major problem with it. But now, I have a project for the simulation of the flow field in an engine. I must say I realy stuked! I am desperate on understanding and solving this problem! I can not find any solution to it. Is there anyone to give me a hint? ---------------------------------------------------------------- Parallel run: Received message from slave ----------------------------------------- Slave partition : 22 Slave routine : ASS_GLOBCS_IAP Master location : Message Handler Message label : 002100088 Message follows below - : +--------------------------------------------------------------------+ | ERROR #002100088 has occurred in subroutine ASS_GLOBCS_IAP. | | Message: | | Could not invert control surface Ap at the following location: | | Domain Interface : R1 to R1 Internal | | Location (X,Y,Z) : ( 0.22981E-01,-0.35690E-01, 0.83732E-01) | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. | | Message: | | Stopping the run due to error(s) reported above |
November 16, 2022, 21:11 |
Rep Power: 32 |
From the message, it seems the equations for the domain interface at the tip gap of your rotor are decoupled.
How did you create the mesh? Using TurboGrid? If you did, check if you can recreate the mesh with a conformal tip gap. It is possible in recent releases of TurboGrid.
November 23, 2022, 12:50 |
QC
Rep Power: 7 |
Dear Opaque
I generated the mesh with Ansys Turbogrid. Before posting my problem here, I tried to change the mesh in the tip clearance region, but I had no progress. Now I am generating the mesh with new parameters. I hope it works! Thanks |
cfx 19.2 |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 05:11 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Invert control surface Ap?? | sercro | CFX | 0 | March 16, 2011 12:53 |
