Element coordinates for momentum source model
Old   October 5, 2007, 07:29
Default Element coordinates for momentum source model
CFDworker
I have some questions for CFX-10. I am working on a momentum source model, where amongst others, the momentum sources are dependent on the radial extent (dr) of the elements.
I am making the momentum source in fortran, and I want to make a User CEL function. I guess the functions USER_CALC_INFO and USER_GET_MESHDATA should be able do do the job, but I don't think there is some real examples of how to implement them in a User CEL function in the CFX manual.
It might be simple for those who are more into it, and they might also argue that it is well documented in the manual, but if anyone has a small example of how to calculate dr or retrieving the coordinates I want, it would be greatly appreciated
Old   October 5, 2007, 10:46
Default Re: Element coordinates for momentum source model
Johnson
You don't need to use USER_CALC_INFO or USER_GET_MESHDATA to do this. Simply pass your variable/expression (dr) as an argument to the function, and it will be available in the ARGS() array in the fortran routine.
See the example on setting a user momentum source (MomentumSource1.F), where X and Y are passed as arguments and used to set the source.
Johnson
Old   October 10, 2007, 08:21
CFDworker
Thank you Johnson,
At first I was kind of looking after the vertex coordinates of the elements, and from these calculate dy and dz of the elements (and afterwards dr). But I don't think I am skilled enough into the data-structure in user Fortran.
Consequently I am using a method much like you suggested to calculate volume sources as a function of the centre of the coordinate centre of the elements
Regards CFDworker
Old   October 10, 2007, 11:05
CycLone
Why do you need the topology at all?
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
momentum source term depending on cell coordinates nikolas FLUENT 0 January 30, 2007 10:00
Problem: buoyancy source term for KE-EP model Andrey V.Ivanov Phoenics 0 May 23, 2003 03:50
2-equation model of LES and source code M.R.Hadian Main CFD Forum 0 February 3, 2002 05:00
