Sample script for ICEM in batch
Old   October 9, 2007, 05:55
Default Sample script for ICEM in batch
nico
hello,
I am looking for a sample script that would give me an idea about how to proceed on the following problem:
*load iges *put mesh parameters (on curves, surfaces) *mesh in tetra + prisms *export to fluent
everything should run through the command line.
Regards,
Nicolas
Old   October 9, 2007, 08:16
Default Re: Sample script for ICEM in batch
Anantha
Hello Nicolas, I assume that you have many number of cases you need to repeat all the steps you have mentioned. There is a replay option in ICEM where in it records all the steps you do. Do all the steps once, starting from model import till mesh export. Keep recording all these steps. You can always edit those if you want to change some of the steps done. In the end you have to save that (as .rpl file). For the rest of the cases, change the file name in the script and then run it as "icem -batch -script test.rpl2", where test.rpl is the file you have saved.
Regards Anantha
Old   December 13, 2012, 10:50
Evgeniy
sportsfun is on a distinguished road
Hello to everybody,
Anantha, when you said "change the file name in the script" what did you exactly mean - changing the name of the file or changing some file name in the script itself?
Regards,
Eugene
sportsfun is offline   Reply With Quote
DPM report sample in batch mode Milano FLUENT 3 August 6, 2012 16:01
running OF on local machine with batch script / job scheduler val46 OpenFOAM 13 November 10, 2010 03:22
DM Script / Batch mode Anantha CFX 0 October 22, 2007 08:47
batch script Miguel FLUENT 0 July 31, 2006 07:51
batch file script to run unsteady flow (les) andi FLUENT 0 April 20, 2004 03:50
