Overlapping isovolume from two cases in CFD post |
December 7, 2022, 08:44 |
Rep Power: 3 |
I have two cases which are identical to each other in geometry and fluid domain. The simulation is injecting a new fluid into a water domain from two different points. I want to see how this new fluid spreads. I have simulated and have got two result files. Now, separately, I have used isovolumes to check the injected fluid at different concentrations. For example, I have looked at regions with 50 percent new fluid concentration. This I am able to do separately. But I want to see the common region in the domain where the fluid in 50 percent for both the cases (injection points).
Can anybody help me find that out in CFD post? |
December 7, 2022, 17:19 |
Rep Power: 143 |
I cannot see how to do this for volumes in CFD-Post. I would export it to a more sophisticated post processor like Ensight, Fieldview or Tecplot and try there. Paraview might be able to do it as well.
December 8, 2022, 04:57 |
Rep Power: 3 |
Can you point me towards some material where I can see how to do this on Ensight?
December 8, 2022, 06:19 |
Gert-Jan
Rep Power: 27 |
It is possible to calculate the difference between 2 cases. I.e., you can subtract one from the other. Not sure of this helps you, but it can bring new idea's and options that lead you to what you are looking for.......
December 8, 2022, 06:42 |
Rep Power: 3 |
Do you know how I can access variables from both cases while creating new expressions? For example, mass fraction of case1- mass fraction of case 2. The mass fraction variable is available by default but I am not sure how to differentiate it between the cases.
Also, by subtraction do you mean using the case comparison option or is there another way to do it? |
December 8, 2022, 07:05 |
Gert-Jan
Rep Power: 27 |
Case comparison indeed. Other options, I don't know.
cfd - post, isovolumes, overlapping |
CFD post case compare | ch@resch | CFX | 1 | December 7, 2022 09:02 |
How to Connect 2 cases in CFD Post | AK5 | CFX | 5 | May 30, 2017 05:11 |
Post-processing star ccm+ results in Ansys CFD Post | sidharath | STAR-CCM+ | 4 | April 10, 2017 11:49 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
Poly lines in CFD Post | ashtonJ | CFX | 0 | December 2, 2010 02:46 |
