constant gradient rate bounday
Old   October 23, 2007, 12:05
Default constant gradient rate bounday
kostas
Hi. I am new to cfx and I am trying to apply a constant gradient rate boundary in an inlet, but i can't find a B.C. like this. Is there any way to apply such a B.C. in cfx?
thank you
Old   October 23, 2007, 13:04
Default Re: constant gradient rate bounday
opaque
Dear Kostas,
I imagine you mean a constant flux, that is grad(phi).normal vector . Then, you can use the Flux in condition, and divide by the "diffusion coefficient" of that equation.
Would you mind explaining what guarantees a gradient at an inlet boundary? Is it for an additional variable with no advection?
Good luck,
Opaque
Old   October 23, 2007, 20:57
HekLeR
For which equation?
Old   October 24, 2007, 04:31
kostas
thnks for the reply
My problem is o buoaunt flow between vertical parallel plates with openings on the top (outlet) and the botton (inlet).
I want to apply a classic Neumann outlet b.c. for the velocity and pressure (without prescribing values for velocity or pressure).
Thank you
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 16:19
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 11:35
how to add heat source with constant temp and heat generation rate leila FLUENT 1 August 19, 2009 00:55
