Contour plot
Old   November 21, 2007, 06:32
Default Contour plot
Magnoli
How can I use a continuous colour gradient in a contour plot in CFX 10.0, instead of the constant colour bands? It was the default option in earlier versions. It must be quite simple, but I just can't find it now in CFX 10.0.
Thanks, Magnoli.
Old   November 21, 2007, 07:42
Default Re: Contour plot
Jim
The best way to do this is to increase the number of contours (i.e. # of contours) to something high like 1000, which will give you the effect you're after .
Old   November 21, 2007, 08:15
Magnoli
This could be a work around, but, in my problem, the processing time is increasing proportionally to the number of contours. In a batch run the total time would be prohibitive for this solution. Is the continuous colour gradient not available in CFX10.0 for contour plots?
Old   November 21, 2007, 09:10
Dr. Flow Squad
Sure it is. Colour the plane instead of using a contour on the plane.
Old   November 21, 2007, 09:16
Magnoli
Thanks, Dr.! That's what I needed and the processing is as quick as it should be.
How to Contour plot for omega_z ?? snehal OpenFOAM 3 March 11, 2017 05:41
Unable to view contour plot on a plane azurespirit ANSYS 0 May 23, 2011 08:35
[OpenFOAM] Contour Plot with Paraview jet ParaView 0 August 26, 2010 10:30
contour plot help jesse@uconn FLUENT 0 February 15, 2010 19:05
to plot Mach contour using GNUPLOT killtimm Main CFD Forum 2 December 28, 2009 11:15
