airfoil stall
Old   November 21, 2007, 08:50
Default airfoil stall
marek
Hi!
I made simulation of flow around airfoil and I got very good results for AOA up to stall angle. I used SST model with gamma-theta transition model, y+ is less than 1 (about 0.75),... I tried with stady state simulation and also with transient but results were the same. Drag was near true but lift was too high because flow didn't separate. Can anybody tell me how can I improve results around stall angle!
Best Regards marek
Old   November 21, 2007, 16:16
Default Re: airfoil stall
A Reynolds averaged approach does not work well for a stalled airfoil. You need to go to LES or DES. Try either the SAS turbulence model or the DES model.
Determining Stall Angle of 2D Airfoil Active.Aero.Fiero FLUENT 3 October 27, 2010 09:07
Airfoil in Stall - Turbulent model. Jack FLUENT 0 November 7, 2008 02:53
Airfoil at stall angle cfd_newbie FLUENT 10 February 5, 2008 11:33
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 02:00
Airfoil in stall Park Geun Hong FLUENT 4 February 24, 2000 21:00
