breakup model for cleaning processes
Old   November 21, 2007, 10:00
Default breakup model for cleaning processes
Tim
I would like to simulate a cleaning process with CFX. The idea is to define particles at the walls of the fluid region and to show, how they are effected by the fluid and transported to the outlet. The next step would be to realise breakup conditions. I read about all the primary and secondary breakup models in CFX, but I have problems to realise it. The particles should keep their position at the wall. If the (drag) forces are big enough the fluid should effect them. Has anyone a idea, which breakup model is adequate for this?
Old   November 21, 2007, 12:08
Default Re: breakup model for cleaning processes
Mihai
Preety interesting what you want to do. First: there exists no drag forces (says literature) that is taking away the particles from a wall. These are the effects of pressure gradients and finally wall stresses. About your question: nobody (as far as I know) has succesfully realised a simulation of a cleaning process-this means a virtually cleaning test.
Old   November 21, 2007, 16:14
I agree with Mihai, I think the model you propose will be very difficult to get accurate. You would need a good knowledge of the adhesion forces of the particles to the walls, the forces between the particles and the fluid at various boundary layer thicknesses, a good description of the surface roughness before and after cleaning etc etc before even considering doing this model the way you propose.
A starting point is to simply do a single phase model and somehow relate a variable like wall shear stress to particle removal. This type of model would be possible but whether it tells you anything useful is another matter.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
