July 4, 2023, 08:56 |
Regarding Multiphase Particle injection
sluzzer
Rep Power: 11 |
Can someone please explain,
1. Why is there a particle injection option both in the domain and in the boundaries? How do these both options differ? 2. Is it possible to use Eulerian + Eulerian + Particle injection? 3. With Opening boundary conditions, it is required to specify the Volume fraction. Is it only the initial values? How to specify the Volume fraction at the opening boundary condition if it is not known? Thank you. |
July 4, 2023, 20:36 |
Rep Power: 143 |
1) There is particle injection options in the domain and boundary levels so you can define particles seeded throughout a domain (eg: particles precipitating out) or the boundary (eg: particles entering through a boundary).
2) Yes, I think so. Try it to be sure. 3) You specify the VF at an opening only for Eularian models. Please note that the definition of a boundary condition is a location where you know enough about the flow that you can define the condition there. If you do not know the reverse flow VF then you cannot put a boundary condition there, and you need to move it to somewhere you do know the fluid condition.
July 5, 2023, 08:34 |
sluzzer
Rep Power: 11 |
Thanks ghorrocks!
Regarding question no. 3: There are some cases where we don't know the VF before the simulation. For example, I am doing a spray or atomizer simulation, where a liquid from the atomizer is sprayed into the chamber having air. The bottom wall of the chamber always has some air recirculation, since the liquid spray is dragging the air along with it. Because of this anticipated air recirculation, I want to use the Opening BC. But how do we know the exact VF at this boundary? (since the amount of air passing through this boundary depends on the liquid spray velocity which is not known accurately before the simulation) Thank you! |
July 5, 2023, 10:44 |
sluzzer
Rep Power: 11 |
Regarding question no. 1:
I find the 'Turbulence induced breakup' option in Domain Particle injection, whereas in BC Particle injection, we need to specify the Particle mean diameter mandatorily. What to do if we want to use the turbulence induced breakup with BC particle injection? Thanks! |
July 6, 2023, 04:40 |
#5 | |
Rep Power: 143 |
Q3:
You can say, however, that the recirculating flow is going to have a VF close enough to zero that I will call it zero. That is what I recommend you do here. If this approximation is not accurate enough for you then you will have to move the boundary further away until it is accurate enough. Q1: There are many ways particles can be generated. Particle breakup is one, and introducing them at boundaries is another. There are many, many more ways of generating them beyond this as well. Or is your question "What to do if we want to use the turbulence induced breakup with BC particle injection?"
Multiphase simulation failing to model sphere-filled composite DEM particle motion | SiemenDiemon | STAR-CCM+ | 3 | December 1, 2020 17:38 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 14:50 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
Multiphase How to controling the time of particle injection | xyq916 | CFX | 2 | January 18, 2015 06:09 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
