Using user function variables in expressions
Like Tree1Likes
  • 1 Post By ghorrocks
Old   July 6, 2023, 08:24
Default Using user function variables in expressions
jlamb is on a distinguished road
I am trying to model a stent in a blood vessel as a type of porous media. To do this, instead of a 3D porous domain, I am attempting to use a 2D interface with a pressure change as defined in the theory documentation. This seems simple enough with constant Kloss and Kperm coefficients but my aim is to have them vary over the stent to represent a heterogenous interface.
As far as I can work out, this should be doable with User Functions and Expressions. Essentially, I have imported spatial data with a Kloss and Kperm variable as an interpolation function (which appear on the right place of my mesh), and have tried to include them in an expression for the pressure change dP.
Unfortuantely, I cannot get this to work I get the error message 'Bad expression value 'dP' detetcted in parameter 'Pressure Change' in object '/FLOW:Flow Analysis 1/DOMAIN INTERFACE:STENT/INTERFACE MODELS/MASS AND MOMENTUM/MOMENTUM INTERFACE MODEL'. CEL error: The following unrecognised names were referenced: Kloss.Kloss, Kperm.Kperm.
It feels like their should be a simple fix but I can't for the life of me figure out, any help would be much appreciated.
jlamb is offline   Reply With Quote
Old   July 6, 2023, 19:42
It says it is just a CEL error, which means you syntax is wrong. Please attach your CCL or output file.
Opaque likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
cel, interfaces, porous media, user functions
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
User field function for specific heat deifnition crevoise STAR-CCM+ 2 January 28, 2013 04:25
