Hi, i'm analysis turbomachinery that air compressor its rpm is 120,000 and flow rate is 0.06kg/s i iterate over 500 but it's not converged, and risiduals oscillation
what is the problem in my case? plz advise me... |
I think you will have to run unsteady case for your problem. Thats what oscillation of residuals indicate.
Usman |
Thx Usman.
i think that if i do unsteady simulation this case it will be take very long time becasuse it's rpm is over 120,000rpm so time step will be very small for corant number. |
Well, pls tell me your geometry of your compressor, I think you are running at a point well beyond surge point. Looks like you are working on a project very similar to mine. MInd to tell me about you and your work? Thanks
This question has been asked hundreds of times before. Look at the FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria Glenn Horrocks |
Thx Glenn.
and I will more carefull before wirete question... |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
directMapped problem | panda60 | OpenFOAM Bugs | 4 | July 8, 2010 10:23 |
calculate time scale for mesh deformation analysis | wilsonbrad | CFX | 1 | October 23, 2009 06:44 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
