October 21, 2008, 09:24 |
Fluent UDF in CFX
Hello All
I have a UDF written in C for use in Fluent Now I began to work on CFX and I am new to using CFX and writing subroutines in it. Is there a way where CFX can compile codes written for Fluent or do I have to write a Fortran code all over again for CFX Thank you Sandilya |
October 21, 2008, 17:18 |
Re: Fluent UDF in CFX
No, you'll need to reproduce it for CFX.
What does the UDF do? Most of what you would do with a UDF in Fluent you can do directly in CFX with CEL. -CycLone |
October 21, 2008, 18:23 |
The UDF adds two new scalar transport equations, one for solving for electric potential in the domain and the other for calculating the ion transport in the domain. These equations are as follows
1) Poisson Equation with space charge source term Del^2(phi) = -ion density/epsilon 2) Ion Transport equation Del.( A*rho + B*rho + C*rho ) = Diff Coeff * [Del^2 (rho)] rho is ion density A , B, C are functions of velocity, phi etc i.e. the two scalar transport equations are coupled and inturn they are both coupled to flow equations What is CEL in CFX and how to include above scalar transport equations in CFX Thank you |
October 22, 2008, 05:42 |
Its easy to do that in CFX using CEL. Have a read about CEL in documentation.
Regards |
October 22, 2008, 10:15 |
Firstly, CFX does not require a user to code additional variable transport equations. In CFX-Pre, just create a new "Additional Variable" for each scalar. You can create these as Volumetric (per unit volume) or Specific (per unit mass) variables and specify their units accordingly. Once you have create the AV's, return to the Fluids Tab on the domain object to define how these are solved. Options include:
Transport Equation (Advection + Diffusion) Diffusive Transport Equation (Diffusion including transient term) Poisson Equation (Diffusion without transient term) Algebraic Equation (Local algebraic equation, no transport) Have a look at Additional Variables in the documentation to see the form of the equations. The CFX Expression Language (CEL) is a unit aware algebraic expression language that is used to interpret all floating point values entered by the user (you are already using it when you enter boundary conditions, fluid properties etc.). You'll note a blue icon with the square root of alpha beside the dialog box when you enter a value. If you click on this, you can enter an algebraic expression instead. CEL expressions can vary in space (X,Y,Z), time (t), with temperature (T, or Temperature), or any other variable available from the solver or in your results (in Post). You can even refer to values at other boundary regions, points in the domain, volumetric averages and so-on. There are some limitations which are imposed to prevent unphysical conditions, for instance you cannot make density a function of space or time. See the help for more details. If CEL does not include a function you need, you can write one in FORTRAN and use it in your expressions. That said, CFX v11 already includes electromagnetics as a beta feature. You can enable beta features from Edit>Options. Add electromagnetic properties to your materials and return to your domain to enable electromagnetic effects. This will be a released feature in version 12, but you can contact technical support for more information in the interim. Basically, the vast majority of things you would do with UDF in FLUENT you can do in CFX directly. CFX users rarely need to write User Fortran routines. -CycLone |
October 22, 2008, 11:55 |
Thank you very much for the detailed response
CFX-User |
October 22, 2008, 17:21 |
Re: Fluent UDF in CFX *NM*
July 24, 2023, 13:13 |
Boussinesq eddy viscosity assumption
prashant godse
Rep Power: 2 |
can we edit Boussinesq eddy viscosity assumption in ansys cfx
July 24, 2023, 18:38 |
#9 |
Rep Power: 143 |
CFX has a range of turbulence models available, and it is possible to define your own turbulence model (but not simple). However you cannot simply change the nature of the built in turbulence models.
July 25, 2023, 09:20 |
#10 |
Rep Power: 32 |
What is the goal of modifying the Eddy Viscosity? How is consistency between all the pieces of an existing turbulence model guaranteed?
Mesh and Solve Times for CFX, Fluent, CD-adapco | Jade M | Main CFD Forum | 4 | August 28, 2012 02:54 |
Import CFX def into Fluent | eric_wang | FLUENT | 0 | April 18, 2011 13:14 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 04:13 |
Jobs in cfd - fluent or cfx? | jobman | Main CFD Forum | 6 | July 5, 2006 15:02 |
