Problem with Spalart Allmaras turbulence model |
July 31, 2023, 16:05 |
David
Rep Power: 2 |
Hello everyone, I wonder if I could get suggestions to solve the following issue.
I did a simulation of a centrifugal compressor using the SST turbulence model in CFX without any problem (the mesh was ok and the y+ was lower than 1) however when I changed to Spalart Allmaras, the simulation crashed after, more or less, 15 iterations. To solve it, I tried to simulate with a less refined mesh in order to use it for the correct one but it failed. Besides, I tried using upwind and first-order schemes instead of high resolution it didn't work. I even tried to use the results from the SST simulation to initialize this one but it crashed. Can anyone give some recommendations about what I could try? |
July 31, 2023, 19:10 |
Rep Power: 143 |
The Spalart Allmaras run crashed - but why? What clues was there leading up to it? Was it diverging? The linear solver failing? Or did it suddenly crash? Did it give any error or warning messages?
Please upload your output file if you want us to look at this.
August 1, 2023, 01:51 |
Stuart
Rep Power: 25 |
Slightly off-topic, but isn't the S-A model in perpetual beta status in CFX? What (if any) wall treatment does CFX use with the S-A model?
August 1, 2023, 03:01 |
David
Rep Power: 2 |
Oh I'm sorry, I will post it on the forum adding the output file
August 1, 2023, 03:13 |
#5 | |
David
Rep Power: 2 |
Yes it is, I had to activate beta features to use it and the wall function that uses the so-called automatic near-wall treatment as default but it can be changed also to the scalable wall function |
August 1, 2023, 03:43 |
Stuart
Rep Power: 25 |
I'd not be surprised there are problems as Ansys clearly aren't going to bring this out of beta status (not that Ansys bother much with CFX anymore anyway).
Searching through the Ansys Customer Portal Knowledge Resources for the S-A model in CFX for any hints does bring up three instances: #610201 What is the y+ requirement for Spalart Allmaras model in CFX? #2029289 How to set boundary conditions for the Spalart-Allmaras-Model in CFX? #2056102 How to set up a simulation, which is using the Spalart-Allmaras turbulence model, in CFX? (includes a PDF). I'm not going to upload them here but I assume you have access as an Ansys customer. |
August 1, 2023, 03:55 |
#7 | |
David
Rep Power: 2 |
I'm not sure if as a student I can access there but I will check it. Thank you |
cfx, spalart allmaras model, sst k-w |
The suitable turbulence model for the problem of flow separation of a sharp edge | Ashkan Kashani | CFX | 3 | September 12, 2023 02:04 |
Problem with creating R file for SSG turbulence model | Khozaei4000 | OpenFOAM Running, Solving & CFD | 3 | April 26, 2022 16:02 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Convergence problem with Spalart-Allmaras Turbulence Model using mass flow at exit | sagarparikh31 | Main CFD Forum | 0 | September 4, 2015 05:25 |
Help Selecting Turbulence Model for VOF Problem | NavierIsStoked | FLUENT | 0 | November 1, 2013 11:27 |
