CFX11 MPICH2 local parallel for windows
Old   January 29, 2008, 01:42
Default CFX11 MPICH2 local parallel for windows
mohanrao
Hi all, I am using CFX11.0 for 64 bit on Computer: Hewlett-Packard HP xw4400 Workstation Intel[R] Core[TM]2 Quad CPU @ 2.66GHz 2.67 GHz, 4GB of RAM
Operating system: Microsoft Windos Xp Professional x64 Edition Version 2003 Service Pack 2
To solve my case of 1 million cells, I use Type of run: Full; Run mode: "MPICH2 local parallel for windows" and set 2 processors.
The computation speed remains the same as that for "serial" single Processor.
How can I increase the computational speed? Kindly help !
Thanks in advance
MohanR
Old   January 29, 2008, 10:41
Default Re: CFX11 MPICH2 local parallel for windows
Bayard Morales
Hi there.
I had some similar experience with parallel runs, so let me asked:
Are you measuring the speed through the CPU second shown in solver out monitor? This is a sum of the CPU solver of your two processors.
I would advise you to do the following benchmark:
- choose a .def and set it for a steady state run for 100 iterations.
- Then, run it with serial and, after finishing it, with MPICH.
Compare the "total wall clock" found at the end of the .out file.
Usually, you should save a nice time with parallel.
Best regards
Old   January 31, 2008, 00:52
mohanrao
Hi Bayard,
Thanks a lot. I followed your steps and got the wall clock time 1.4 time lower for the parallel computing. (i was measuring the CPU speed earlier)
Thanks again .
Best wishes, Mohan R
Old   March 31, 2009, 10:01
onder
mztcu is on a distinguished road
hi I AM STUDENT
I WANT, MODELİNG FROM SHİP HULL AROUND FREE SURFACE WAVE. I HAVE XP SP2 64BİT AND I LOADED CFX11 BUT NOT RUN ON XP32 BİT İT RUN. WHY CFX11 DONT RUN ON XP64 BİT . YOUR CFX11 İS FOR 64BİT SYSTEM OR NORMAL CFX FORM NET CRACKED.
mztcu is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
