4 (one core) or 2 (double core) processors?
Old   February 19, 2008, 07:02
Default 4 (one core) or 2 (double core) processors?
Gen
Hi all! What do you recommend for parallel solving by ANSYS CFX? 4 (one core) or 2 (double core) processors; 8 (one core) or 4 (double core) processors? Thanks for your response!
Old   February 19, 2008, 07:17
Default Re: 4 (one core) or 2 (double core) processors?
Bart
As most new (faster) processors are at least dual core, single or dual core is not really a choice (single core is just too old). You have to look at what processor is fastest PER core. So it's either 4 dual core used as single core or 2 dual core using 4 cores. Then the memory bus is the bottleneck (both cores need access to the same memory). Comparing quad cores to dual cores the fastest processors PER core are to my knowlegde still dual cores. We recently opted for Intel Xeon 5160 (dual cores) where only one core per processors is used. You can save money on hardware using all cores on the processors, but most of the money goes to the parallel licenses (paid per used core). The money/performance ratio is than shifted to using 1 parellel license per processor (using only 1 core per processor). I hope this makes sense.
Old   February 19, 2008, 08:00
Dre
This is somewhat related. I found it very interesting.
http://www.cad-fem.de/fileadmin/file..._Platforms.pdf
Go Barcelona!
Old   February 19, 2008, 08:53
Bart
Excellent link. Thanks for that. But: Go Barcelona????? Conclusion says intel Xeon 5160, taking everything into account (scaling, license cost etc). Problem with Harpertown is availability. Barcelona is good if licence costs are not an issue (free parallel codes).
Old   February 19, 2008, 12:37
Dre
Well I think it's obvious that parallel computing is the new direction. Maybe not new, but getting cheaper, more sophisticated and more acceptance. You'll have to embrace sooner or later.
I'm also an AMD supporter
Old   February 19, 2008, 16:31
Bart is definitely right for commercial ANSYS CFX customers - the license cost for parallel licenses far exceeds the hardware cost so Woodcrest 5160 is a clear winner on this basis. However, for academic customers who pay a far lower price for the software the equation may be different and it may be better to use a larger number of slower CPUs (such as the AMD CPUs) that run better in parallel.
Old   February 20, 2008, 02:15
Gen
Thank you all! Your advices are very useful for me.
Old   February 20, 2008, 03:25
Bart
Sniff sniff, :,-( I used to be AMD supported (had one at home also). But it looks like AMD is in its final days.
CFD: one major player: Ansys CPU: one major player: Intel
so much for competition
By the way. I had a look at the CADFEM presentation from Dre. New Harpertown Xeon CPU's are available (X5460, 3+ GHz). It might tip the scale from he Xeon 5160 to the new quad cores (buy less CPU's use them as multicore and save some on hardware with the same or more speed). I'm reconsidering my upcomming purchase of a new cluster. Thanks Dre again!!!
Bart
Old   February 21, 2008, 05:35
alterego
Any suggestions if it would be worth the wait for the new Xeon 5482 3.2GHz with 1600 FSB to be available?
Were heading for a new server with 2 Quadcore CPUs.
Old   February 21, 2008, 05:48
Bart
The latest information I have is that the increase in bus frequency (from 1333 to 1600 MHz) doesn't help as the Xeon memory bottleneck is still there. However, the new Harpertowns Xeon's do scale better than the older 5160 (dual cores) and are just faster per core. So I would disregard the Bus frequency and go for the fastest quad core harpertown Xeon.
Bart
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 08:20
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
