November 20, 2023, 14:58 |
reverse flow in centrifugal fan blades
kalm
Rep Power: 2 |
hello everyone. I am trying to analyze an tested centrifugal fan with cfx. CFX results are 20% lower than the test results at high pressures and close to the test results at low pressures. I tried all input and output combinations but the results did not change. I ran it with transient and the results are still incorrect. When I looked at the flow with the cfd post, I noticed that there was a reverse flow in front of the wing. Where do you think the problem might be? The photo about this is attached.
November 20, 2023, 16:41 |
Rep Power: 143 |
A large separation like that means the design is not running very well and will have large losses. This is a real effect, and is the reason turbomachines have a peak performance point, as off the design point things like this will happen.
So if the expected performance is significantly higher than CFX predicts, and CFX predicts a large separation like that (which would cause a large loss in performance) then the question is who did CFX incorrectly predict a large separation. It could be: * Inappropriate physical model (eg wrong turbulence model) - what turbulence model did you use? * Inaccurate simulation technique - did you do a mesh sensitivity study and a convergence sensitivity study? See https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F * Boundary conditions not specified correctly - are you sure your boundary conditions match what the experiment did? Things like surface roughness, upstream turbulence are key factors as well. * Poor experimental accuracy
November 21, 2023, 00:58 |
kalm
Rep Power: 2 |
thank you for the answer . I tried SST and k-epsilon turbulence model, the result is the same. I also did a mesh density study. There is no convergence problem, even very fast convergence. I analyzed only the propeller without an interface with the mesh I created in Turbogrid. The vector lines appear smooth at the total pressure inlet and mass outlet. The mass inlet is at the static pressure outlet and when I interface it to the outlet of the propeller, the vector lines are wrong again.
November 21, 2023, 01:58 |
#4 | ||
Rep Power: 143 |
Can you show the experimental results you are comparing against, and the results you are getting? ALso please attach your output file.
November 21, 2023, 09:30 |
#5 | |
Rep Power: 32 |
How many elements per passage of the wheel are you using? What is the mesh density near the walls? Y+ near 1?
November 21, 2023, 14:25 |
kalm
Rep Power: 2 |
Experimental results: 3500 Pa pressure at 2.96 m3/s flow rate, 2950 Pa at the stage interface, 2650 Pa at the frozen interface in the analysis. Even if I increase the number of meshes, the results do not change much. Mesh photos are attached.
LIBRARY: CEL: EXPRESSIONS: fan pst = massFlowAve(Pressure )@S1 Outlet-massFlowAve(Pressure )@S1 \ Inlet END END MATERIAL: Air Ideal Gas Material Description = Air Ideal Gas (constant Cp) Material Group = Air Data, Calorically Perfect Ideal Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-2 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END MATERIAL: Air at 25 C Material Description = Air at 25 C and 1 atm (dry) Material Group = Air Data, Constant Property Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1.185 [kg m^-3] Molar Mass = 28.96 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-02 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.003356 [K^-1] END END END MATERIAL: Aluminium Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2702 [kg m^-3] Molar Mass = 26.98 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 9.03E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 237 [W m^-1 K^-1] END END END MATERIAL: Copper Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 8933 [kg m^-3] Molar Mass = 63.55 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 3.85E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 401.0 [W m^-1 K^-1] END END END MATERIAL: Soot Material Group = Soot Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2000 [kg m^-3] Molar Mass = 12 [kg kmol^-1] Option = Value END REFERENCE STATE: Option = Automatic END ABSORPTION COEFFICIENT: Absorption Coefficient = 0 [m^-1] Option = Value END END END MATERIAL: Steel Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 7854 [kg m^-3] Molar Mass = 55.85 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 60.5 [W m^-1 K^-1] END END END MATERIAL: Water Material Description = Water (liquid) Material Group = Water Data, Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 997.0 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4181.7 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 2.57E-04 [K^-1] END END END MATERIAL: Water Ideal Gas Material Description = Water Vapour Ideal Gas (100 C and 1 atm) Material Group = Calorically Perfect Ideal Gases, Water Data Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 18.02 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 2080.1 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1.014 [bar] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 100 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 9.4E-06 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 193E-04 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END END FLOW: steady SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: R1 Coord Frame = Coord 0 Domain Type = Fluid Location = impeller BOUNDARY: Domain Interface 1 Side 1 Boundary Type = INTERFACE Location = inflow impeller BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Domain Interface 2 Side 1 Boundary Type = INTERFACE Location = outflow impeller BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: R1 Blade Boundary Type = WALL Coord Frame = Coord 0 Frame Type = Rotating Location = blade BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: R1 Hub Boundary Type = WALL Coord Frame = Coord 0 Frame Type = Rotating Location = hub BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: R1 Shroud Boundary Type = WALL Coord Frame = Coord 0 Frame Type = Rotating Location = shroud BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Alternate Rotation Model = true Angular Velocity = 2950 [rev min^-1] Option = Rotating AXIS DEFINITION: Option = Coordinate Axis Rotation Axis = Coord 0.3 END END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = None END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = SST REATTACHMENT MODIFICATION: Option = Reattachment Production END TRANSITIONAL TURBULENCE: Option = Fully Turbulent END END TURBULENT WALL FUNCTIONS: Option = Automatic END END INITIALISATION: Coord Frame = Coord 0 Frame Type = Rotating Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic END STATIC PRESSURE: Option = Automatic END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END END DOMAIN: S1 Coord Frame = Coord 0 Domain Type = Fluid Location = volute BOUNDARY: Domain Interface 1 Side 2 Boundary Type = INTERFACE Location = impeller volute in BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Domain Interface 2 Side 2 Boundary Type = INTERFACE Location = impeller volute out BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: S1 Default Boundary Type = WALL Location = \ F268.288,F269.288,F270.288,F271.288,F272.288,F273. 288,F274.288,F275.28\ 8,F276.288,F277.288,F278.288,F279.288,F280.288,F28 1.288,F283.288,F284.\ 288,F285.288,F286.288,F291.288,F292.288,F293.288,F 294.288,F295.288,F29\ 6.288,F297.288,F298.288 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: S1 Inlet Boundary Type = INLET Coord Frame = Coord 0 Location = inlet BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Total Pressure Relative Pressure = 0 [atm] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: S1 Outlet Boundary Type = OUTLET Location = outlet BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Mass Flow Rate = 3.52 [kg s^-1] Mass Flow Rate Area = As Specified Option = Mass Flow Rate END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = None END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = SST REATTACHMENT MODIFICATION: Option = Reattachment Production END TRANSITIONAL TURBULENCE: Option = Fully Turbulent END END TURBULENT WALL FUNCTIONS: Option = Automatic END END END DOMAIN INTERFACE: Domain Interface 1 Boundary List1 = Domain Interface 1 Side 1 Boundary List2 = Domain Interface 1 Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = Stage DOWNSTREAM VELOCITY CONSTRAINT: Frame Type = Rotating Option = Constant Total Pressure END END PITCH CHANGE: Option = Specified Pitch Angles Pitch Angle Side1 = 360 [degree] Pitch Angle Side2 = 360 [degree] END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: Domain Interface 2 Boundary List1 = Domain Interface 2 Side 1 Boundary List2 = Domain Interface 2 Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = Stage DOWNSTREAM VELOCITY CONSTRAINT: Frame Type = Rotating Option = Constant Total Pressure END END PITCH CHANGE: Option = Specified Pitch Angles Pitch Angle Side1 = 360 [degree] Pitch Angle Side2 = 360 [degree] END END MESH CONNECTION: Option = GGI END END OUTPUT CONTROL: MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR POINT: pst Coord Frame = Coord 0 Expression Value = fan pst Option = Expression END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END END SOLVER CONTROL: Turbulence Numerics = High Resolution ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Iterations = 200 Minimum Number of Iterations = 1 Physical Timescale = 0.01 [s] Timescale Control = Physical Timescale END CONVERGENCE CRITERIA: Residual Target = 1e-5 Residual Type = RMS END DYNAMIC MODEL CONTROL: Global Dynamic Model Control = Yes END INTERRUPT CONTROL: Option = Any Interrupt CONVERGENCE CONDITIONS: Option = Default Conditions END END END END |
November 21, 2023, 14:30 |
kalm
Rep Power: 2 |
I also tried with the full model and single passage. I made 12 blades with a single blade and 1M mesh, but the results still do not change. Max y+ 62 in the whole model.
November 21, 2023, 14:36 |
#8 | |
kalm
Rep Power: 2 |
Hello . I noticed something like this. As the blade height decreases, the pressure should decrease. In my analysis, by decreasing the blade height from 100 mm to 90 mm, the pressure increases. While the blade height is 100mm, the pressure is 2950 Pa, while the blade height is 90mm, the pressure is 3280 Pa. |
November 21, 2023, 15:25 |
#9 |
Rep Power: 32 |
If your mesh has a Y+ on the boundary of 62, there is absolutely no point in using SST. SST requires Y+ <= 1 throughout all the walls.
If your full model is not capturing the experimental data, then you have a bigger problem: 1 - Either the experimental data is bogus 2 - The setup is incorrect somewhere, for example: a - it may not be representative of the experiment. b - your transient is not timestep independent c - your mesh refinement is not capturing the regions of high gradients d - your frame change interface may be incorrectly set e - have you checked the impeller is rotating in the correct direction? I have seen it all in rotor-stator setups f - may I ask why are you running transition at all? Keep it simple: no transition, no reattachment g - why are you not using Automatic for the Pitch Change model? h - Finally, you got to be kidding using an incompressible material in a compressor/fan. You MUST use Air Ideal Gas. Air at 25C is incompressible
November 21, 2023, 15:38 |
#10 |
kalm
Rep Power: 2 |
Which turbulence model do you recommend? In this way, the results of a different fan that I analyzed completely matched the experimental results and there was no reverse flow around the blade. I think the reverse flow around the blade of this fan causes the results to be incorrect.
November 21, 2023, 18:43 |
#11 |
Gert-Jan
Rep Power: 27 |
- In these cases not solely look to Velocity but also at Velocity at Stationary Frame.
- Your vectors are very unclear. Please add better pictures where direction is more clear. (e.g, white background, equally spaced vectors, uniform length, projected etc.) - Like Opaque mentioned, check the rotation direction. In >95% of my setups, the rotation direction has to be negative to let it rotate in the required direction. - Having these recirculations has nothing to do with right or wrong. These could be realistic very well, depending on the operational point. Can you explain where on the curve you are operating? - I would start with Frozen rotor and Automatic Pitch. Since it is 360°, CFX will be able to determine the best settings automatically. - Turn off the Alternate Rotation model. Mostly not required. - Start with Auto timescale. I think a physical timestep of 0.01[s] is way too large. With almost 3000 rpm, i.e. 50Hz, it takes 0.02[s] to make one revolution. - Alternatively go to transient. I have seen bad results turn to good ones, by switching to transient. Especially with radial fans. - Don't use Transition at this stage. Only use it as a very, very, very last resort. Just use SST. Should be fine. As long as Y+ is below 300, I would not expect a major difference. Last edited by Gert-Jan; November 22, 2023 at 01:00. |
November 22, 2023, 11:29 |
#12 |
kalm
Rep Power: 2 |
Thank you very much for your answer. I will try your advice. I work at the most productive point of the curve. Vector, convergence and static pressure screen photos are attached.
November 22, 2023, 17:04 |
#13 |
Rep Power: 143 |
Your blade geometry is just a simple curved plate. I would expect that to separate at just about every flow condition (including peak performance). In fact I would think it very difficult to find a condition where that geometry would not separate.
For the flow to be attached you need carefully shaped blades with airfoil cross-sections. It would need carefully angled entry and exit angles. In other words - I think your CFX results are correct, this design should have a big separation in it.
November 22, 2023, 17:38 |
#14 |
kalm
Rep Power: 2 |
Thank you very much for your reply . You are so right Glenn. I had previously analyzed a fan with a different geometry with a lower time interval, its results matched the experimental results, there was also separation in the blades of that fan. Now I will try this fan with a low time step.
CFD Online is a very nice site. You are doing great work by taking the time to help. Thank you very much again. Kind regards . |
November 29, 2023, 06:08 |
#15 |
kalm
Rep Power: 2 |
Hello friends . I ran the fan test again and the results were the same as the previous experiment. I confirmed that my analysis results were incorrect. If I start the analysis with automatic time scale, it matches the experimental results, but the residuals do not go below 1^10-4. When I increase the automatic time scale factor in the solver, the pressure drops rapidly. Where could the problem be? I would be very happy if you help.
November 29, 2023, 14:18 |
#16 | |
Rep Power: 32 |
When you increase your timescale, what happens to the residuals? Up/down, stays fixed? When the residuals stay at a fixed value above expectations (mine expectation is 1E-5 or below), you should go to Output Control/Results/Output Equation Residuals = All Run the simulation, post-process the results (converged or not) and check where the region of large residuals are. Try to understand what is happening around there: mesh quality, unphysical results, stagnant flow, etc.
November 29, 2023, 16:54 |
#17 |
kalm
Rep Power: 2 |
Thank you for your reply. When I increase the time scale, the residuals quickly decrease to 1e-5 and the pressure quickly moves away from the experimental results. When I switch from steady to transient with adaptive time step, the residuals drop below 1e-5 in the first few iterations. In CFD post, residues remain high in regions where the speed is low. Network quality seems good in these regions. Do you have any other suggestions regarding this?
November 29, 2023, 16:58 |
#18 |
Rep Power: 143 |
Can you show an image where you show the high residual regions?
When you run transient you will need to run for enough time steps to capture any transient behaviour. This means a few cycles of any transient behaviour. You cannot just run a time step or two.
December 1, 2023, 06:40 |
#19 |
kalm
Rep Power: 2 |
Thank you for your answer . I ran a new analysis to view the residuals. photos have been added. I tried everything you said but I couldn't find where I was doing wrong. Do you have any other suggestions? Thank you very much
December 1, 2023, 18:12 |
#20 |
Rep Power: 143 |
You will need to redo the residuals images with a higher residual. The setting you currently have is showing too much. You need to look at the worst bit where you are only starting to get a small bubble of volume as that will show where the most difficult locations are.
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
Axial fan compressor - Mass flow not matching | miguel_mazzu | CFX | 3 | December 3, 2017 18:33 |
Thrust in Axial flow fan for different inlets | acoustica | CFX | 8 | April 24, 2014 03:44 |
axial flow in counter rotating ducted fan | Vishu | FLUENT | 4 | January 13, 2004 17:52 |
