CFX fan modelling: Issue in pressure drop measurement |
December 27, 2023, 01:42 |
Rep Power: 12 |
Hello experts,
I have a technical query related to the pressure drop measurement in an enclosure. When we use a smaller axial fan (e.g., an exhaust fan) in an enclosure, will it cause an additional pressure drop? See below image from a CFX simulation. Towards the fan entry, there is a sudden drop in pressure. Is this due to a sudden contraction of the flow path? Is this behavior expected if we use a cooling fan on any device? Initially, I have simulated using MRF/Frozen rotor approach; A similar behavior is observed. The attached image is a simplified case, where conditions are: Inlet: Static Pressure 0Pa Outlet (After the fan): Mass flow rate is specified |
December 27, 2023, 04:38 |
Rep Power: 143 |
The pressure drop as you approach the fan inlet is just Bernoulli's equation - as the fluid speeds up its pressure will reduce.
cfx, fan as momentum source, fan boundry conditions, momentum sources, mrf |
Pressure Drop Pipe Measurement Location | JHAM | Main CFD Forum | 1 | June 12, 2017 17:12 |
CFX Pressures | frossi | CFX | 3 | July 2, 2016 06:51 |
CFX Modelling issue | Ben Mc | CFX | 40 | November 1, 2013 04:25 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
