How to apply angle of attack on a 2D axisymmetric body? |
January 29, 2024, 12:04 |
Saikat Pradhan
Rep Power: 4 |
I’m doing cfd simulation of rocket on Ansys cfx, the geometry of rocket is 2D axisymmetric. How can I apply angle of attack on rocket? Last edited by funnier; January 29, 2024 at 17:10. |
January 29, 2024, 16:12 |
Rep Power: 143 |
I presume the rocket is long and cylindrical, possibly with a conical nose. And by angle of attack you mean the rocket is not travelling in the direction of its axis, it is slightly off.
In this case the simulation is not a 2D axisymmetric model any more. You can going to have to use the full 3D geometry. You may be able to use a symmetry plane depending on what wake structures you expect to see (some wake structures are non-symmetric, so you would need a full 3D model with no symmetry plane to capture these).
January 29, 2024, 17:11 |
Saikat Pradhan
Rep Power: 4 |
I uploaded picture of the rocket. Can you please look at it?
January 29, 2024, 17:29 |
Rep Power: 143 |
As I said, you are going to have to generate a full 3D model of this. So take your 2D slice and rotate it around to generate a 3D body. Then do a rotation on the body it to generate the angle of attack you want.
You will then have to remesh and run the simulation again as a full3D model. It will take a lot longer to run, of course, as the mesh will be much larger.
angle of attack, axisymetrical, axisymmetric, axisymmetric 2d cfx, cfx & fluent |
Calculating Oscillating Aerofoil Angle of Attack | MechEng86 | FLUENT | 1 | August 20, 2019 08:19 |
Angle of Attack simulations | redordead | FLUENT | 2 | June 15, 2016 03:50 |
how to plot attack angle along with impeller span direction at leading edge | wildli | FLUENT | 0 | August 31, 2010 14:47 |
convegence problem with high angle of attack | littlelz | CFX | 2 | October 28, 2009 06:07 |
Proper output of angle of attack in CFX post | Kevin | CFX | 3 | October 18, 2006 12:18 |
