Error when using -maxet to limit the runtime of job |
February 25, 2024, 10:07 |
KristianRanta
Rep Power: 9 |
I'm running a job on a cluster that requires me to input an estimated overall runtime. In order to preclude the job from aborting without writing a .res file of all the progress made in case the actual runtime exceeds my prediction, I want to limit the run time using the -maxet command. The CLI command I type in is Code:
cfx5solve -maxet "200 [min]" Code:
-def <def file name> Code:
-use-mesh-from-iv |
February 25, 2024, 16:52 |
Rep Power: 143 |
No, you are heading in the wrong direction there.
A much simpler way of getting it to attempt to stop the solver at a defined time is to use the Elapsed Wall Clock Time Control in the solver tab of CFX-Pre. Then no command line options are required.
February 25, 2024, 23:12 |
KristianRanta
Rep Power: 9 |
Yes, that is an option. However, I want to specifically be able to change it during runtime to give me more flexibility. See, there is an option on the cluster to extend/lower the wall clock time as the run is progressing, and I'd like to adjust my runtime settings accordingly. Hence, I was going the CLI route.
February 25, 2024, 23:29 |
Rep Power: 143 |
Use "edit run in progress" to change it during a run. This is an option in Solver Manager.
And all these functions can be called from the command line if you want.
February 26, 2024, 10:01 |
Rep Power: 33 |
You have not described your current model workflow in detail.
Are you using a multiconfiguration setup or just a simple analysis? could you post the exact command line you are using?
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
Duplicate entry alphaContactAngle in runtime selection table fvPatchField | Roesch | OpenFOAM Programming & Development | 2 | January 12, 2021 03:35 |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 12:36 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
cfd job | Dr. Don I anyanwu | Main CFD Forum | 20 | May 17, 1999 15:13 |
