negative turbine outlet total pressure(harmonic balance) |
April 7, 2024, 05:58 |
Zhuolin Zhao
Rep Power: 2 |
hello everyone,
During the numerical simulation of 1.5stage Turbine, I came across a description of a negative pressure value and I hope I can help. When I simulate this turbine, the inlet is given Total pressure and total temperature. The outlet boundary condition is a fixed mass flow rate, and some cooling fluids also specify mass flow rate and temperature. When I was simulating using the harmonic balance method, I found that the pressure value at the outlet had a very negative value, and because I needed to use this value to perform exponential calculations, the solution failed. I would like to ask how to solve this problem and want to know the reason(But neither RANS nor URANS simulations have this problem) The formula involved: pToalNGV2Outlet in: (1-(pTotalNGV2Outlet/pTotalNGV1Inlet)^((gammaAVG-1)/gammaAVG) is a negative value pTtalNGV2Outlet=0 [Pa] + massFlowAve(Total Pressure in Stn Frame)@NGV2 Outlet Error massage: +--------------------------------------------------------------------+ The problem was: | Follower: 2 | INVALID-EXPONENTIATION | Follower: 2 | | Follower: 2 | FURTHER INFORMATION | Follower: 2 | | Follower: 2 | The problem was encountered in executing the expression for: | Follower: 2 | dhTotalIsTurbine | Follower: 2 | The complete expression is: | Follower: 2 | CpAVG*( mFlowTotalNGV1Inlet*tTotalNGV1Inlet*(1-(pTotalNGV2Outle \| Follower: 2 | t/pTotalNGV1Inlet)^((gammaAVG-1)/gammaAVG))+mFlowTotalNGV1RIDNI \| Follower: 2 | nlet*tTotalNGV1RIDNInlet*(1-(pTotalNGV2Outlet/pTotalNGV1RIDNInl \| Follower: 2 | et)^((gammaAVG-1)/gammaAVG))+mFlowTotalNGV1RODNInlet*tTotalNGV1 \| Follower: 2 | RODN | Follower: 2 | The error occurs on sub-expression: | Follower: 2 | (pTotalNGV2Outlet/pTotalNGV1Inlet)^((gammaAVG-1)/gammaAVG) | Follower: 2 | | Follower: 2 | BACKGROUND INFORMATION | Follower: 2 | | Follower: 2 | The error was detected at one location. The same problem may be | Follower: 2 | present at other locations - that has not been investigated. | Follower: 2 | The following values are for the first location which has the | Follower: 2 | problem. | Follower: 2 | | Follower: 2 | In this expression, these sub-expressions have been calculated: | Follower: 2 | | Follower: 2 | Sub-expression = Value | Follower: 2 | | Follower: 2 | mFlowTotalNGV1Inlet*tTotalNGV1Inlet = 15587.8 | Follower: 2 | These values were set before reaching the current expression: | Follower: 2 | | Follower: 2 | Name = Expression = Value | Follower: 2 | | Follower: 2 | tTotalNGV1TECInlet = massFlowAve(Total Temperatu= 320.922 | Follower: 2 | tTotalNGV1RimSeal...= massFlowAve(Total Temperatu= 323.294 | Follower: 2 | tTotalNGV1RailFlo...= massFlowAve(Total Temperatu= 301.310 | Follower: 2 | tTotalNGV1RODNInlet = massFlowAve(Total Temperatu= 324.617 | Follower: 2 | tTotalNGV1RIDNInlet = massFlowAve(Total Temperatu= 323.324 | Follower: 2 | tTotalNGV1Inlet = massFlowAve(Total Temperatu= 330.457 | Follower: 2 | pTotalNGV2Outlet = -4.275651E+14 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ This is my first time asking. If there is anything unclear in the description, please forgive me and tell me and I will add it in time. Thanks |
April 7, 2024, 18:53 |
Rep Power: 143 |
There are many problems this could be.
It could be numerical - your simulation is inaccurate, or during convergence some parameter is far enough out that it causes this problem I cold be real - is this a compressible fluid flow? Have you checked it is not choked flow? Have you checked your boundary conditions are correct and well-posed?
April 8, 2024, 03:34 |
Zhuolin Zhao
Rep Power: 2 |
hello,
The whole process can be regarded as an incompressible fluid. I also checked the boundary conditions several times. The same situation did not appear in the RANS and URANS simulations, although they were the same boundary conditions. The same for chocked flow. Is there a way to look at specific numerical issues? Thanks for your reply |
April 8, 2024, 05:05 |
Rep Power: 143 |
The CFX documentation states: "it is essential to use the smallest number of harmonics at which the solution accuracy is acceptable.". So have you tried increasing the number of harmonics?
April 8, 2024, 08:36 |
Rep Power: 32 |
May I ask why you are running a transient simulation with outlet mass flow?
For a turbomachine the outlet mass flow is not a steady value, it fluctuates and it is a function of the motion of the rotor upstream. In addition, are you using a fixed mass flow, or an expression-based mass flow and adjusting it as you go. Keep in mind that during convergence, the solution fields are not guaranteed to be physical (it helps if they are).
April 8, 2024, 08:40 |
Zhuolin Zhao
Rep Power: 2 |
Thanks for this idea, I will try it and give you a feedback.
April 8, 2024, 08:44 |
Zhuolin Zhao
Rep Power: 2 |
hello,
This setting is based on a turbine test rig in Uni. This may be the real situation, but a fixed outlet mass flow rate value is specified as a boundary condition in the numerical simulation, which will definitely include approximations. So this part should not be a physical problem, because many previous simulations have verified it. Thanks |
April 8, 2024, 09:37 |
#8 | |
Rep Power: 32 |
We can make similar cases for compressible flow. Summary: using fixed outlet mass flow for unsteady flow after rotating components is not a good practice.
April 8, 2024, 09:39 |
#9 |
Zhuolin Zhao
Rep Power: 2 |
got it, I will think about that. Thanks
fatal overflow, harmonic balance, negative total pressure |
Garrett Turbocharger - turbine outlet temperature | Vijay_Kunisetty | STAR-CCM+ | 0 | August 28, 2023 00:41 |
Gas turbine combustor modelling - uburned fuel at the outlet | Andrea1984 | FLUENT | 0 | May 14, 2014 06:56 |
the static pressure at one outlet is negative? | yuhehuan | Main CFD Forum | 7 | August 15, 2013 21:01 |
Modeling transient negative pressure (suction pressure) in outlet | N_mrtz | FLUENT | 1 | July 18, 2013 20:59 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
