have anybody use the LES in CFX?
Old   March 26, 2008, 09:42
Default have anybody use the LES in CFX?
Wei
Hi, everybody.
Did someone have use the LES in CFX? if someone have do a CFD on a ribbed channel or a U-bend channel using the LES in CFX, Could you tell me the result? is it better than any RANS?
Thank you!
Wei.
Old   March 26, 2008, 16:26
Default Re: have anybody use the LES in CFX?
Whether LES is better than RANS depends on what you are trying to do! The literature shows many examples when RANS gives a more accurate result than LES.
CFX can do LES. There has been many posts on the issue on this forum recently. Also look in the CFX documentation as it discusses the LES models it has.
Old   March 26, 2008, 20:54
Wei
thank you, Horrocks. you said, there are many examples show the RANS gives a more accurate result than LES. But, according to the literature I have read. the LES is better than RANS almost. As you said, It may be depend on the issue. My research problem have big separation, reattachment,and second flow. In a word, the flow is too complicated.
Old   April 17, 2008, 19:34
Kushagra
try out one LES simulation...setting up LES in CFX is very simple..just you need a fine mesh and a small time step.... take a time step based on your guess on RANS experience, see the residuals....and then decide if you need to decrease.....each time step should converge within 3-4 or 5 iterations.....otherwise use adaptive time step scheme...
only one problem so far with LES in CFX that I have found that 'opening' type boundary condition may cause the linear solver to fail...same has been mentioned in the CFX documents...
so give it a try.......in my case the flow is highly complicated..still no initial flow field was required....you can give some RANS soution as initial guess...it will converge faster...
Hope it helps and Good luck !
Kushagra
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 06:30
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 02:54
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
