Lagrangian Particle Tracking model In CFX
Old   April 11, 2008, 15:15
Default Lagrangian Particle Tracking model In CFX
Kushagra
I am facing big times problem with the Lagrangian particle tracking model in CFX. I simulated flow in a hydrocyclone and once I obtained quite good flow field, I started tracking the particles with all the applicable forces applied (Turbulent dispersion force, pressure gradient force, gravity, byouancy) BUT I get wrong results all the time.
Could some one comment his experiences with Lagrangian model and accuracy of it in CFX-11? I have heard from other people as well that they have been facing the same problem as that of mine.
Please help. Thanks very much.
Regards, Kushagra
Old   September 19, 2009, 11:57
Rodrigo Vallejo Pereira
rvallejo is on a distinguished road
I´m facing the same problem. Could anyone help us ?
Thanks
rvallejo is offline   Reply With Quote
Old   September 19, 2009, 19:16
John is on a distinguished road
Originally Posted by Kushagra
;87439
Regards, Kushagra
Can you provide details what's wrong with your results?
John is offline   Reply With Quote
Old   September 22, 2009, 12:57
Lagragian model provides a result where all the particles go to the underflow. I 'm using turbulent dispersion and Schiller Naumann drag force. I've tried virtual mass force and pressure gradiente force in addition, but they didn't work as well.
I'm using ANSYS CFX 11.01.
Best Regards,
Vallejo
Old   September 26, 2009, 18:20
Best Regards,
Vallejo
Old   March 12, 2010, 18:26
lee
leeportnoff is on a distinguished road
When the particle diameters become small (less than 10 microns in air) the fluid can no longer be considered continuous. The drag coefficient on each particle, which is calculated using standard correlations (Schiller Neauman), must be divided by the Cunningham correction factor. The correction factor is greater than 1 which means that the effective particle drag coefficient goes down.
The cunningham correction factor is not used in CFX but if you use the "Particle Transport Drag Coefficient" in the Momentum Transfer tab in Pre you can specify any drag model that you need using CEL relations. First try to redo the Schiller Nauman relation, verify it with the CFX implementation and then correct it with the Cunningham factor. The Schiller Nauman will be the hardest part because it is an implicit relation.
leeportnoff is offline   Reply With Quote
Old   May 12, 2010, 04:50
Reine Granström
gravis is on a distinguished road
Does anyone have experience carrying out this implementation in CFX?
gravis is offline   Reply With Quote
Old   May 12, 2010, 05:41
charles
sei2006 is on a distinguished road
check your turbulence model firstly.
sei2006 is offline   Reply With Quote
Old   December 2, 2010, 21:18
lee
LEVEL OF DIFFICULTY: ADVANCED
To get this working, I had to write a custom FORTRAN routine based on the pt_mom_source.F file included in ANSYS.
I compiled a custom pt_mom_custom.dll,
Expressions, functions, and variables > user routines > insert user routine and call 'drag'
option: particle user routine
calling name: pt_mom_custom
library name: pt_mom_custom
library path: <path to winnt> containing pt_mom_custom.dll
Then insert User Function
user routine name: drag
argument units: []
results units: []
Now, in your domain, under the 'Fluid pair models'
for 'drag force' select 'none'
check 'particle user source'
you should see your 'drag' routine for particle user routine
Lastly choose arguments and return variables.
** important ** the order you select these variables must match the order in your pt_mom_custom.h routine. i.e. It is by order of appearance, that cfx knows input DIAM_PT means particle.Mean Particle Diameter.
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
Lagrangian particle tracking jiejie OpenFOAM 15 July 19, 2017 11:18
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
2D vs 3D model, Eulerian vs Particle tracking Itchie CFX 0 April 10, 2008 05:04
