ran out of temporary space
Old   May 14, 2008, 13:42
Default ran out of temporary space
Al Mazdeh
Have u seen this error massage?
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | SYMASS_ZIFCS_EL : The solver ran out of temporary space while bui- | | lding a linked list for a domain interface. Try setting the expe- | | rt parameter "topology estimate factor zif" to a value greater th- | | an 1.0. Values higher than 1.2 should not be necessary.
I have set the expert parameter to 1.2 but I still recieve the same error.
I was able to run a file larger than this
Old   May 27, 2011, 09:09
rskrishna87 is on a distinguished road
yes i have see nti now when i tried to transfer mesh from icem to cfx and tried to run it.Did u get the solution bychance
rskrishna87 is offline   Reply With Quote
RAM and Swap Space and HD space Anindya Siemens 2 May 25, 2016 21:40
Connect two pipes with different space stap CFDDmitry Main CFD Forum 0 May 19, 2011 07:24
Error Message - No Space recon9 CFX 3 January 29, 2011 13:41
How to model the NR eqns in a domain with empty space Vasilis Main CFD Forum 1 April 14, 2009 04:35
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
