turbulence model for a square-based cylinder
Old   June 13, 2008, 13:24
Default turbulence model for a square-based cylinder
paul
Hello, I work on an air flow around a square-based cylinder, I have to study a large range of Reynolds number (from 1 to 100 000), which turbulence model should I use in CFX ? I already tried k-epsilon bit it didn't give results expected. Thanks a lot
Old   June 13, 2008, 23:27
Default Re: turbulence model for a square-based cylinder
Rogerio Fernandes Brito
I think u should choose all of them to show the diffrences among them! How about it and have a good work!
Old   June 15, 2008, 22:12
Hi Paul,
That range of Re goes from stokes flow (very laminar) to highly turbulent. No turbulence model is going to be able to give sensible results for such a wide range.
Obviously the laminar model will be the one to choose up until the turbulence starts. In the turbulent region it will depend on the results you want (eg lift/drag or more detail than that). As Rogerio says best to try them for yourself and find out.
Old   June 16, 2008, 10:39
paul
Hi, thanks for your response. My main issue concerns the turbulent region. With Re=3000, I have tried several models (Shear Stress Transport, k-epsilon..) and I have no vortex shedding! Consequently, I was wondering which model would be more relevant. Paul
Old   June 16, 2008, 21:57
To get accurate vortex shedding you also have to have a good mesh, get the timestep right, have a 2nd order spacial and temporal discretisation scheme, sufficient convergence etc etc. Are all these things under control? Only then should you think about the turbulence model - and also keep in mind the different turbulence models require different meshes. It is not a matter of simply flicking over to a new turbulence model.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
