Velocity source
Old   June 16, 2008, 05:16
Default Velocity source
sergio
Hi I would like to put inside a domaine a velocity source. i explain more...
I have a domain made of two part dividede by a line with 3 open, in the central opening I'd like to set velocity condition. I must check air flow in all the domain (also out of velocity source).
how can I do?
Thanks
Old   June 16, 2008, 21:48
Default Re: Velocity source
Use a source term to fix the velocity in the opening to the value you want. Look up source terms in the documentation.
Old   June 17, 2008, 03:03
sergio
Ok I see! I have bad convergenze, I use highres e phisical timescale 0.01s My domain is 500x1500x500 mm with velocity imposed of 6 m/s
thanks
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Heat source as a function of velocity on a plane Nicki CFX 2 May 20, 2009 04:46
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
convert velocity in momentum source Mark Render Main CFD Forum 1 July 26, 2002 17:20
