CFX-Solver error (double precision)
Old   June 25, 2008, 02:32
Default CFX-Solver error (double precision)
icem-noob
Hi Guys
After changing my solver-option to "double precision", CFX displayed following error message while exiting the computation: "Warning: formatted floating point data is only written to single precision data"
what does that mean, and what difference can I except to my displayed results?
Old   June 25, 2008, 12:24
Default Re: CFX-Solver error (double precision)
Raj
Hi
It depends on the size of the problem which you Solve and the Memory your machine has while formatting the results.
Are you using cluster to run your Model
Old   June 25, 2008, 14:44
icem-noob
Hi
nope, no clustering and no very high memory computation. I got approx 150k cells running on my dual core cpu. the thing is, I just have a 32bit windows... this could be the problem actually.
Old   August 25, 2013, 07:24
Robert
Robertz is on a distinguished road
Hi, i have the same problem. I'm using a cluster and i tried to increase my memory by using "-size 2". The error message still appears. Is this the right way to solve the problem and my memory still isnt large enough?
And what does it mean for the results? Are they solved with double precision and only saved in single precision?
Thanks a lot!
Robertz is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
How to start CFX Solver with an existing parfile lentschi CFX 3 February 20, 2011 13:31
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
amd athlon64 cpu and cfx 5.7.1 solver cmete CFX 3 October 20, 2005 22:16
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
