compressor simulation question
Old   June 26, 2008, 21:42
Default compressor simulation question
Noureddine
Hi everybody,
i want to know how i can simulate a compressor in ANSYS-CFX 11 by using the general simulation type (i mean not the turbomachinery one)..... what about the radial equilibruim at exit?
thanks,
Noureddine
Old   June 27, 2008, 07:42
Default Re: compressor simulation question
pankaj
Hi Noureddine!
See you want a general mode simulation then,import mesh for compressor,its casing and in/out domains,apply boundary conditions and this will do.
Means u have to hndle a 360 deg case with Volute mesh(separate one).
there is nothing extra special .
Pankaj.
Old   June 27, 2008, 10:12
Noureddine
Hi Pankaj,
first, thank you for your quick answer.
in my case i want to simulate one blade passage of an axial compressor.
I want to know if there is an exit boundary condition suitable for rotating machines like in conventional turbomachinery codes where we specify a static pressure in one radial position (hub or casing) and extrapolate it using a radial equilibrium condition.
Regards,
Noureddine
Old   July 2, 2008, 06:50
Pankaj
Hi!
What is the reason u want to specify pressure in radial condition? Actually i dont know abt other codes but in CFX it will be better if u prepare a model with In,out,periodic for one passage,use mfr approach to solve axial flow impeller.
Still if u know better ways,then dont divert your own path.
Regards, Pankaj.
Old   July 2, 2008, 10:31
Noureddine
Thanks again Pankaj,
for Ansys-CFX, it is not my choice to work with it, they imposed it to me for my PhD research.
In my master, i developped my own code for transonic compressors using a Time Marching Method (without turbulence... i failed to converge with the Baldwin-Lomax model...i did not have enough time), and in all documentations about the numerical simulation in turbomachinery, u can see that they all use the radial equilibrium for exit condition.
Best Regards,
Noureddine
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
