July 3, 2008, 18:55 |
Pressure gradient for channel flow??
Hi
I am running a plane channel flow using periodic boundary. I have specified pressure drop between inlet and outlet. Do I need to set pressure gradient as well under sub-domain?? Thank you for your help. |
July 3, 2008, 22:22 |
Re: Pressure gradient for channel flow??
No. The pressure drop comes from the pressure loss of the flow through your modelled domain.
Glenn Horrocks |
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 08:55 |
pressure input, mass flow output | Venugopal Bachu | Main CFD Forum | 0 | January 11, 2007 10:01 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
