July 26, 2008, 10:47 |
No Heat Transfer between two solid domains
I am setting a simple case to test the multiple solid and fluid domains.
Water and Air domains were separated by 2 different solid domains connected by solid-solid interface. This test case is trying to get the temperature and flow field in the water enclosed by solid domain A. Heat transfer from constant temperature wall to the air and solid domain B is visible (Not converged after 10000 iterations (the energy in the water domain can not converged), but very stable) The problem is there is no heat transfer from solid A to solid B, no heat transfer from water to solid A. I had set [CFX5_NO_CONSTANT_PHYSICS=T] in the environment variable. I could setup the two fluid properties at two different fluid domain. I also set the [CHECK ISOLATED REGIONS=F] But this doesn't help. Please give me some hint how to solve this problem. I had searched the forum but did not find the answer. I used [HEAT EXCHANGER] and [TWO FLUID DOMAIN] and some other keyworks to read most of the questions back to 2002 but did not find the answer. I am new to CFX. Please help me....... I am waiting here for the answers. Best. |
July 26, 2008, 12:29 |
Re: No Heat Transfer between two solid domains
send me your file to me for giving a look: rogeriobrito2007@hotmail.com
July 26, 2008, 15:59 |
hello, Roderio,
I had send the def file to your email. Please help me check it. Thank you very much. |
July 26, 2008, 16:06 |
ok
July 26, 2008, 16:44 |
I changed some things, and iīm going to send the link with new files. I donīt know if these changes were good as you wanted.
July 26, 2008, 16:46 |
July 26, 2008, 16:48 |
Once I received your file. I will run it. It may take 30 minutes.
I will keep you post here with new results. Thanks a million. |
July 26, 2008, 16:50 |
Make a simulation up to 100 iterations and tell us what it will happen! Mey MSN is rogeriobrito2007@hotmail.com, 05h51min. PM, saturday, in Brazil.
Best Regards |
Heat transfer between fluid-solid domains doesn't occur | Gandin | FLUENT | 37 | August 1, 2019 02:29 |
Simulation of a Silo | Attesz | CFX | 20 | October 15, 2010 08:11 |
Heat Transfer between two liquids domains | Abhishek | CFX | 3 | December 25, 2004 03:43 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Heat transfer through solid | Chris | FLUENT | 0 | March 10, 2003 06:49 |
