ROTATING RESERVOIR
Old   August 28, 2008, 22:37
Default ROTATING RESERVOIR
S. KRISHNAN
I seek your help in solving a flow problem. the description of the problem is:
A hollow cylindrical vessel, rotating at 5000 rpm having a small orifice on the outer wall. It is filled with a liquid. I want to simulate the flow and find out how much time it would take to empty the cylinder.
Please give your expert advice
Old   August 29, 2008, 12:05
Default Re: ROTATING RESERVOIR
F S
Hi
Make a cylindrical domain with fluid as Air. Place your vessel in this domain (select the fluid as water). Assign your vessel as rotating wall.
Good luck
Old   August 30, 2008, 07:46
F S
PS: You ll need to do a transient simulation.
Old   September 4, 2008, 02:42
S. KRISHNAN
My specific question:
In this problem, the inner boundary is moving towards the outer boundary with respect to time. Should we assign mesh motion? If so how it can be given? Should it be given as a CEL? Also the dimensions of the fluid domain are: Outer diameter: 36mm Inner diameter: 20mm Length: 15mm Orifice diameter : 0.5mm Number of orifices : 1
Can we model it as a quarter of the cylinder and apply symmetric boundary? Also tell me about the meshing process.
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
