September 5, 2008, 04:43 |
Perl script for intialisation
I am in need of a perl script for my CFX run , i need a script which does the first solver run with steady state for 200 iteration and later transient for specifed number of total timesteps and Max coefficent loop of 3 per timesteps. here in my script I have made two .def files one steady and another one unsteady , all I need this script to run the steady file and later run unsteady with initialization with the result file of steady state
I have my script as shown but it doesnt work at all , could anyone please tell me where are the mistakes ? ************************************************** ** %run1= (NAME => "run1", INIT => ""); %run2= (NAME => "run2", INIT => "run_001.res"); # Define a list of definition files to run @runList = ("\%run1", "\%run2"); foreach $run (@runList) { if (!defined($run->{NAME})) { print "Found run without a name.\n"; $errors = 1; } if (!defined($run->{INIT})) { print "No initial file found for " . $run->{NAME} . ".\n"; $errors = 1; } } #loop over the list foreach $run (@runList) { $name = $run->{NAME}; $initFile = $run->{INIT}; #Open the solver to accept some CCL from STDIN open(SOLVER,"|cfx5solve -def steady.def -name $name $initCmd -part 2 -start-method \"MPICH2 Local Parallel for Windows\" "); } # end of loop ********************************************** Thank you in advance for your kind response |
September 9, 2008, 11:24 |
Re: Perl script for intialisation
Let me make life easier for you. Run a steady state flow and then initialise your unsteady flow with steady state results. Easy peasy
September 10, 2008, 03:09 |
hello,
Thats what I want to do using the script since I have many such cases to run for different geometries, In all I have 8 definition file and each one needs this process of steady state run and later transient run. My entire goal is to do this by perl script , So I need some help in making the script which will do the things as mentioned thanks for your kind reply |
[ICEM] Script: problems with face names | Maweil | ANSYS Meshing & Geometry | 3 | April 16, 2019 09:10 |
Using Perl script and power Syntax in CFX-Pre | omidiut | CFX | 3 | October 18, 2011 06:10 |
perl script error (looping) | amazdeh | Main CFD Forum | 0 | September 11, 2009 12:47 |
Solver Control via .pre file with Perl script | ahlo | CFX | 1 | March 7, 2008 12:33 |
Time-steps via Perl in CCL | Rui | CFX | 5 | March 29, 2004 00:47 |
