ICEM BC to FLUENT
Like Tree2Likes
  • 2 Post By Simon
Old   September 9, 2008, 09:36
Default ICEM BC to FLUENT
Simon
Hello:
I have searched this forum and found the post about requiring LINE elements in order to have FLUENT recognize the BC created in ICEM. However, I still do not understand how one outputs an ICEM 11.1 mesh, with its boundary conditions, for FLUENT v6.3.
I can successfully output the mesh from ICEM to FLUENT. My problem lies with defining the boundary conditions (BC) in ICEM so that they are recognized by FLUENT. I have tried setting the BC in the ICEM Output BC window, but that does not work.
Can someone please provide me with a simple procedure? This task for a 2D quad mesh.
Old   September 9, 2008, 14:45
Default Re: ICEM BC to FLUENT
myron
Make sure the curves bounding the 2D surface are placed into appropriate 'Parts' so you can specify boundary conditions on those 'Parts'. When you create the mesh - those bounding curves should translate to LINE elements in the appropriate parts. So if you don't have LINE (1D) elements separated into your desired BC groups (Parts) - that is the problem.
Old   September 9, 2008, 15:43
Simon
Myron:
Thank you. I hear what you are saying, it is similar to the other post that I saw. However, I am not sure that I understand how to implement your explanation.
Let us imagine that I have a very simple geometry, a rectangular box from creating four curves from four points. The four curves are used to create a surface. I create part INLET using the left curve, part OUTLET using the right curve, part WALL using the top curve, and part SYM using the bottom curve. I use autoblock to mesh the surface.
If I understand you correctly, I need to return to my parts (INLET, OUTLET, WALL, and SYM) and associate them with the corresponding line elements if I want those parts to be BC's in FLUENT. Is that correct?
If the above is correct, would I turn off all geometry, turn on the mesh, and add the necessary line elements? Am I creating the line elements?
Thank you.
Old   September 9, 2008, 17:08
Simon
Okay, this issue has been resolved. The process is indeed as I wrote above, after being prompted by Myron.
After the mesh was created and I had a good mesh quality. I turned off all geometry, leaving MESH enabled. I then added the appropriate LINES to my respective PARTS (e.g., inlet). I used the selection box, which made it very easy. I then returned to the OUTPUT tab to specify the BCs and write the .msh file. When I had FLUENT read the .msh file, all of my BC's were there.
I took the time to write what I did in hopes of helping the next person who is coming from another CFD software tandem to ICEM/FLUENT.
-Simon
hadikhayyamian and Obed like this.
Export 2D mesh from ICEM to Fluent enghamed ANSYS Meshing & Geometry 18 August 10, 2015 20:49
[ICEM] domain interface in ICEM for fluent hsn ANSYS Meshing & Geometry 24 November 27, 2012 16:43
Dimension conflict between icem cfd and fluent highhopes ANSYS Meshing & Geometry 1 September 9, 2011 11:07
Problem with ICEM and Fluent: Automatically created Regions within the domain sandmike_83 ANSYS Meshing & Geometry 0 September 24, 2010 05:42
ICEM 2d mesh to fluent hsn CFX 2 June 5, 2008 14:45
