Concentric tube heat exchanger (Air-Water)
Old   October 1, 2008, 02:50
Default Concentric tube heat exchanger (Air-Water)
Young
Dear all,
I have tried to run a certain concentric pipe heat exchanger but now I'm frustrated.
I made a model in design modeler of workbench as follows:
1) make inner circle and extrude it then the cylinder was freezed. 2) Make outter circle and extrude it then it is an encloser of the inner circle 3) Using "Form a part" to make two solids as one.
Then I execute the mesh. There is no problem.
In the CFX-Pre, I checked interface and inlet outlet condition.
But It makes always the same error ;
Writing crash recovery file | +--------------------------------------------------------------------+ ---------------------------------- Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
__________________________________________________ ___
I used the air at STC and Water at 25C, which have the density value (I have checked millon times)
but CFX can not find the fluid density.
Is it mesh problem?
Is it geometry problem?
I thought it is a simple heat exchanger problem but it's not.
Who is the man to sucess running a concentric heat exchanger?
Would you let me know how you do model and run the heat exchanger problem?
Old   October 2, 2008, 06:50
Default Re: Concentric tube heat exchanger (Air-Water)
rohit
Dear young,
are you properly defining the two domains in CFX pre..? did you checked whether you have selected cprrect fluid names from the fluid list for both the domians
Old   October 2, 2008, 12:10
Young
Thanks rohit for your concerns.
I selected the Air at STC in the fluid list of CFX-pre for air tube fluid.
and Water (constant property liquid) in the fluid list.
Am I worng?
Old   October 2, 2008, 18:11
Please post the CCL of the run at the top of the output file.
Old   October 3, 2008, 00:43
Young
Thank you for your concerns.
I always appreciate your kind and valuable recommends in this web site.
Here is my CCL for my simple but ugly heat exchanger.
Hopefully, you can find what is wrong and what I should do.
Thank you again.
+--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+
LIBRARY:
MATERIAL: Air at STP
Material Description = Air at STP (0 C and 1 atm)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.00366 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.725E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.284 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 0 [C]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0038E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.428E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Reference Temperature = 25 [C]
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END
END END FLOW:
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SIMULATION TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Default Domain Modified
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at STP
Location = B114
BOUNDARY: Default Domain Modified Default
Boundary Type = WALL
Location = F115.114,F127.114,F142.114,F143.114
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Adiabatic
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: Default Fluid Fluid Interface Side 1
Boundary Type = INTERFACE
Location = \
F117.114,F125.114,F119.114,F118.114,F116.114,F123. 114,F126.114,F121.1\
14,F122.114,F120.114,F124.114
HEAT TRANSFER:
Option = Conservative Interface Flux
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ain
Boundary Type = INLET
Location = F128.114
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = -11.3 [C]
END
MASS AND MOMENTUM:
Normal Speed = 1 [m s^-1]
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: aout
Boundary Type = OUTLET
Location = F129.114
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
END
DOMAIN: wat
Domain Type = Fluid
Fluids List = Water
Location = B130
BOUNDARY: Default Fluid Fluid Interface Side 2
Location = \
F126.130,F119.130,F124.130,F125.130,F123.130,F122. 130,F117.130,F116.1\
30,F120.130,F121.130,F118.130
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: wat Default
Location = \
F131.130,F132.130,F133.130,F134.130,F135.130,F136. 130,F137.130,F138.1\
30,F139.130
HEAT TRANSFER:
Heat Flux in = -50 [W m^-2]
Option = Heat Flux
END
Option = No Slip
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: watin
Location = F140.130
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Static Temperature = 45 [C]
END
MASS AND MOMENTUM:
Normal Speed = 0.3 [m s^-1]
END
TURBULENCE:
END
END
END
BOUNDARY: wout
Location = F141.130
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
END
PRESSURE AVERAGING:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
END
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
Option = Scalable
END
END
END
DOMAIN INTERFACE: Default Fluid Fluid Interface
Boundary List1 = Default Fluid Fluid Interface Side 1
Boundary List2 = Default Fluid Fluid Interface Side 2
Interface Type = Fluid Fluid
INTERFACE MODELS:
Option = General Connection
FRAME CHANGE:
Option = None
END
PITCH CHANGE:
Option = None
END
END
MESH CONNECTION:
Option = GGI
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
END END COMMAND FILE:
Version = 11.0
Results Version = 11.0 END EXECUTION CONTROL:
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: chae
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
Host Architecture String = intel_xeon64.sse2_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = F:/Thesis/prelim/test/002/minihs4.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
END
LICENSE CONTROL:
Preferred License = 35
Shared License Port = 2033
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END
+--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | | | ANSYS CFX Solver 11.0 | | | | Version 2007.01.15-19.20 Mon Jan 15 19:24:21 GMTST 2007 | | | | Executable Attributes | | | | single-int32-32bit-novc6-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2007 ANSYS Europe Ltd. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+
Run mode: serial run
Host computer: CHAE Job started: Wed Sep 24 16:43:44 2008
+--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 217758.5 3146.16 955.78 850619.1 12584.65 Integer 60150.9 869.06 264.01 234964.4 3476.23 Character 2885.9 41.70 12.67 2818.2 41.70 Logical 65.0 0.94 0.29 253.9 3.76 Double 608.0 8.78 2.67 4750.0 70.27
+--------------------------------------------------------------------+ | ****** Notice ****** | | Wall Heat Transfer Coefficient written to the results file uses | | "Wall Adjacent Temperature" for the bulk temperature. If you want | | to override the bulk temperature then set the expert parameter | | "tbulk for htc = <value>" | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Mesh Statistics | +--------------------------------------------------------------------+
Domain Name : Default Domain Modified
Total Number of Nodes = 29514
Total Number of Elements = 105046
Total Number of Tetrahedrons = 105046
Total Number of Faces = 39348
Minimum Orthogonality Angle [degrees] = 32.0 ok
Maximum Aspect Ratio = 5.6 OK
Maximum Mesh Expansion Factor = 17.0 ok
Domain Name : wat
Total Number of Nodes = 39700
Total Number of Elements = 122787
Total Number of Tetrahedrons = 122787
Total Number of Faces = 77494
Minimum Orthogonality Angle [degrees] = 34.6 ok
Maximum Aspect Ratio = 13.4 OK
Maximum Mesh Expansion Factor = 16.2 ok
Global Statistics :
Global Number of Nodes = 69214
Global Number of Elements = 227833
Total Number of Tetrahedrons = 227833
Global Number of Faces = 116842
Domain Interface Name : Default Fluid Fluid Interface
Non-overlap area fraction on side 1 = 0.00E+00
Non-overlap area fraction on side 2 = 0.00E+00 ---------------------------------- Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
+--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ ---------------------------------- Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+
End of solution stage.
+--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as F:\Thesis\prelim\test\002\minihs4_003.res.err | | and may be an aid to diagnosing the problem or restarting the run. | | More details should be available in the solver output section of | | the output file. Note that a lock file was left for the crash | | file when the solver exited, and so it is probably incomplete. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | The following user files have been saved in the directory | | F:\Thesis\prelim\test\002\minihs4_003: | | | | mon | +--------------------------------------------------------------------+
This run of the ANSYS CFX Solver has finished.
Old   October 6, 2008, 23:17
I can't pick the problem after a quick look. I would build the simulation up again, first one domain, then the other then other connected by an interface.
Concentric Tube Heat exchanger (pipe in pipe) in 2D ckliew ANSYS 0 February 24, 2011 07:48
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Heat Transfer Coeff on the water air interface Anton Main CFD Forum 3 June 2, 2010 01:49
FSI error ERROR #001100279(Shell & Tube heat exchanger) Chandrashekhar CFX 3 March 26, 2010 15:04
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
