Slow down on local parallel
Old   October 9, 2008, 13:47
Default Slow down on local parallel
Roger
Hi
I have a question about parallel performance. Im using a quadcore processor with only 2gb of memmory running on win xp. I have set up a 2D model and the solver slows down the more cores I use when I run in local parallel mode. For me it is a lot faster to run in serial mode. Is this because the bottle neck is the communication between the different partitions or is there another explanation?
Best regards
Old   October 9, 2008, 17:15
Default Re: Slow down on local parallel
CycLone
If it is a small grid, the communication overhead may be greater than the parallelization benefit. That said, if you're running with PVM on Windows you may see better performance by using MPICH (or MPICH2 on XP64) instead.
-CycLone
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
