November 13, 2008, 08:15 |
Free Surface Position
Hi
I wonder if anyone can help me. I am trying to run a simulation based on a torpedo floating on the surface of the sea. I am not planning on implemeting waves to the calculation yet but it is a thought for the future. My problem is that I cannot seem to get the free surface in the correct position. I have set the CEL Expressions and even run a number of simulations (rough ones) to try and get a picture of where the free surface lies but it is not in the right position (in the middle of the torpedo). Also If anyone can tell me how to upload a picture to a post I can post a couple of pictures to explain what i am talking about more clearly. Can anyone help with this, How do I move the free surface into the correct position and what boundary condition should I use for the side of the model, i thought opening would be best but I dont know the values to use. I am relatively new to CFX and have not been using it for long. Many thanks Jen |
November 14, 2008, 07:08 |
Re: Free Surface Position
Best if you check what your mesh looks like (i.e. how many elements depth-wise) near the free surface - are you using structured or unstructured? Cheers, latslosh |
November 16, 2008, 16:46 |
Make shure your mesh is dense around where you expect the surface to be. You should calculate about 4 mesh cells in the precision you want to determine the surface level at.
For example, if you want to calculate the surface level within 10mm, you should have 2-3 mm mesh size in the surface normal direction. Parallel to the surface the mesh can be less dense, that's why structured mesh is usually superior in this application. |
November 17, 2008, 01:51 |
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 11:44 |
Submarine Free Surface | samwh | CFX | 7 | August 30, 2009 07:14 |
Free surface height v/s time | ashish | CFX | 2 | October 4, 2005 14:13 |
Free surface modelling under CFX 4 | Dahong | CFX | 2 | June 22, 2002 23:07 |
CFX 4.4 New free surface option | Michael Rasmussen | CFX | 3 | October 5, 2001 13:24 |
